2013 F250 4X4 Extreme Rough Ride - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-16-2013, 08:55 PM Thread Starter
Hey Guys - I have seen previous posts in the past about "the wobble" but i just don't think that's the issue with my truck. It's more like the feeling of running on ruts. Our freeways are pretty rough in CA and when driving at 70 it feels like the shocks just aren't compressing at all. On smooth roads the truck is fine. So, I am thinking it's simply the fact there is no weight in the rear, slightly overinflated tires, but my question to the group is.
How much do you think dumping the stock Rancho Shocks for the higher end Bilsteins would make a big difference? Also, question about overall suspension. Thinking about three inch full suspension lift and going to 33's. How much do you think that will soften it?
Thanks all!!!
mc2013 is offline
post #2 of 9 Old 10-16-2013, 09:24 PM
Black2011SD's Avatar
Going to 33"s with a 3" lift?
Black2011SD is offline
post #3 of 9 Old 10-16-2013, 09:58 PM
You'll want 35s on a smaller wheel like 17 or 18. Find a lighter tire as well and it might ride smoother. The stock tires are over 34 inches tall.
2 inch lift will fit that, there are some softer riding lifts out there, research them.
Rednecktastic is offline
post #4 of 9 Old 10-17-2013, 01:12 PM
Skyd Ram's Avatar
Quoted: 130 Post(s)
What wheels and tires are you running and at what pressure?
What is the cab/bed configuration of your truck?
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #5 of 9 Old 11-04-2013, 08:42 AM Thread Starter
Thanks for the note and sorry for the delay. Was on a biz trip. My truck is stock, so I looked at a lift kit as an option this past weekend. Going 4-6 inch lift with 35's. I am also picking up this new storage system called a DECKED that adds about 200 to the whole bed. So, hoping this softens things for me.
mc2013 is offline
post #6 of 9 Old 11-04-2013, 08:45 AM Thread Starter
So, I went to 4-Wheel Parts as they are one of the only shops here in town. I was thinking of their Pro-Comp Stage 1, lift kit with Bilstein Shocks, but was also looking at either King or Fox. I don't need it for any hard off-road performance...
Appreciate the thoughts on 35's with the smaller wheel...that should soften things up.
mc2013 is offline
post #7 of 9 Old 11-04-2013, 08:50 AM
Skyd Ram's Avatar
Quoted: 130 Post(s)
35's on a smaller wheel (with lower pressure) along with a little extra weight in the bed will help for sure.
Don't expect to get much ride improvement with most lifts and in some cases it can get worse. The kind of stuff that they sell at 4 wheel parts are purely to get the truck taller and/or look cool.
For 35's I would suggest staying around 2.5" of lift and running a "suspension system" like Carli or Pure Performance. Their stuff is actually designed to improve the ride and performance while lifting the truck.
888-886-2480
Skyd Ram is offline
post #8 of 9 Old 11-04-2013, 04:10 PM Thread Starter
Talked to the guy today at 4WheelParts - He recommend going with a 4 inch FabTech lift with Dirt Logic shocks. I will check out the two other companies you noted tonight. I haven't heard of them. I will be at SEMA this week as well, so I will check them all out.
mc2013 is offline
post #9 of 9 Old 11-04-2013, 04:42 PM
I would do something like a 2.5 inch leveling kit, new track bar, f350 rear blocks and leaf pack in the rear. Bilstein shocks. 17 inch wheels and 35 inch tires. You might be even able to go to D load rated 315/70/17 All Terrains if the load rating is ok on them.
Leaf pack should help smooth out the rear some because it should remove the overload springs and take up some of the lift block spacing. On most 4 inch lifts they rely on blocks to lift the rear which mess up the ride. No wild cards on the front if you keep the stock front springs as well.
Good luck.
