10,000 LB GVWR package? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-10-2013, 09:37 PM Thread Starter
I have a 2012 srw, 6.7L F350 xlt,4x4, SuperCab, short bed, with snowplow package. There is also a "10k GVWR package." which I never realized was a thing until now. What is this, with out stating the obvious?...meaning what physical parts make it have a lower weight rating than the typical 11.5k rating?
Everything else seems the same. The combined vehicle weight rating mirrors the 11500k trucks,(23500) as well as my gross axle weight ratings (6k front, 7k rear). The axles are the same, the shocks are the same, the frame is the same. As far as I can tell, I can't see any difference between identical 10k gvwr f350s and 11.5k GVWR f350s, besides the door placard stating such....unless I'm missing something obvious.
Of Note: I originally bought and registered it in MA. They have crazy Nanny state DOT laws regarding vehicle weights, and Ford states on their Tow Guide page; "If your vehicle will be registered in California, Connecticut, Maine, Maryland, Massachusetts, New York, Oregon, Rhode Island, or Vermont, check with your Ford dealer to be sure the desired powertrain/axle ratio is available in your area." Could it be a similar issue, in that it is legally required in certain states, i.e. vehicles with a GVWR of over 10k fall into a different category?
This is kind of driving me nuts getting to the bottom of...10k vs 11.5k, makes a drastic difference in calculating legal towing weights in correspondence with what the vin card says.
Any insight would be greatly appreciated.
titusg77 is offline
post #2 of 11 Old 10-10-2013, 09:52 PM
Quoted: 14 Post(s)
I know it was mostly to deal the registration in states like yours, where anything over 10,000lbs required bigger fees to register. But what, if anything physically that Ford actually down graded, I have no idea.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #3 of 11 Old 10-10-2013, 10:07 PM Thread Starter
Thanks. I have a suspicion you're right.
Also of note, the front coils are increased to 6k with the plow pack, and an extra leaf was added in the rear for a total of 5 in the pack and 1 helper.
titusg77 is offline
post #4 of 11 Old 10-11-2013, 05:51 PM
Nothing physically is different between the 10,000 GVWR and 11,500 trucks except a sticker. As said before, it's only for registration in particular states or personal preference.
What it means for you is that you can only have (legally) a total of 10,000 lbs weight on the truck. This includes the weight of the truck, passengers, and any cargo. It does not include something you're towing. Those with the regular 11,500 have the freedom to legally load up to 11,500 total lbs.
Hope this helps.
jgross433 is offline
post #5 of 11 Old 10-13-2013, 11:14 AM Thread Starter
Thanks. I verified the same thing. That additional 1, 500 lbs of gvrw left on the table makes an absolutely huge difference in what one can tow legally, essentially putting you down in a towing weight class with large suvs. Great, my 1 ton diesel with 800ftlbs of torque can almost match a Lincoln Navigator in tongue weight. Seems such an obvious thing to check before buying, but somehow it just didn't occur to me that such a "package" would exist. Lesson learned
titusg77 is offline
post #6 of 11 Old 10-13-2013, 11:26 AM
Quoted: 2 Post(s)
The likelyhood of a trooper pulling you for scale is slim to none unless you're deserving of harassment.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #7 of 11 Old 10-13-2013, 01:48 PM Thread Starter
Probably true, especially outside of the nanny states. It could become an insurance issue in an accident though.
titusg77 is offline
post #8 of 11 Old 10-13-2013, 01:51 PM
ucpa111's Avatar
Quoted: 3 Post(s)
Likelihood of getting pulled over is slim. But, get into an accident with a load and the other guy has a decent lawyer....hope they don't investigate the weight.
Many people risk this. Personally, that liability isn't worth my estate.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #9 of 11 Old 10-13-2013, 01:57 PM Thread Starter
Agreed there. Old Murphy and I are pretty close. Just when you think he's not around...
titusg77 is offline
post #10 of 11 Old 10-13-2013, 02:14 PM
The 10K package basically turns your truck into a 250 that has an extra leaf in the rear.
2011 F260 6.7 CC 4x4 LB
gsxr1300 is offline
