2015 powerstroke gt37 turbocharger! - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 38 Old 10-09-2013, 07:14 PM Thread Starter
I'm really curious and want an honest opinion on if you guys think the new gt37 will give mild performance over the current gt32 or will it give an insane boost in performance the specs of the gt37: inducer size of 63.5 with an exducer/ compressor 88/72.5 is that going to be a huge difference or just a mild I just bought my truck and I'm kinda disappointed now that I find this out!
d1rty-max is offline
post #2 of 38 Old 10-10-2013, 04:31 AM
George C's Avatar
It's a definite leap forward, but the biggest leap is the increased overall fuel flow potential. The new engine is a huge improvement over all.
The biggest problem with a 12' is a 13'. Biggest problem with a 14' is the 15'.
Enjoy your current ride because there will always be improvements you can't keep up with. I'm still waiting for the redesign, so it looks like I stick what I have for another year. One can't win.....
Sent from AutoGuide.com App
2008 F-350
KEM 345 tuned.
George C is offline
post #3 of 38 Old 10-10-2013, 03:54 PM
ciscofreak's Avatar
If you're in to low end power, the GT32 will most likely kill the GT37 when it comes to more aggressive low end spool. I build 2 to 5lbs of boost at 1000rpms. I doubt the GT37 will match that.
The GT32 definitely runs outta air quickly though where my 6.0l would just be getting going where the 32 left off.
13 F350 Lariat CC LWB
ciscofreak is offline
post #4 of 38 Old 10-10-2013, 07:28 PM
The 32 pulls loads with ease like no other. Happy with what I have. Specially since I have a tune I'm happy with
09 white fx4, icon leveled..37x12.50 toyo mt,20in rockstars,spartan 275,4in tbe,s@b intake
hammett88 is offline
post #5 of 38 Old 10-20-2013, 11:41 AM
ciscofreak's Avatar
I'm looking forward to the GT37. I really like the low-end pull of my 13 but it flat-out runs outta steam at 2800. It feels exactly like a cummins. I miss the pull to 3800 of my 6.0.
post #6 of 38 Old 02-21-2014, 06:25 AM
Hope to have my 15 350 end of April. Give me a few miles pulling 10k boat over mountain s in as and Bill let you know results
stang77 is offline
post #7 of 38 Old 02-21-2014, 06:35 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Looking forward to hearing your result's.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #8 of 38 Old 02-21-2014, 03:34 PM
POWERCHOKER
Dantron's Avatar
What the difference between low-end power and high-end power? I understand the RPM range aspect, but I'm having difficult picturing what situations will see the most benefit.
Dantron is offline
post #9 of 38 Old 02-21-2014, 04:42 PM
from what i got out of this is each chargers strong points , (gt32) much shorter power band more boost down low , (gt37) much longer power band through out the rpm range . i could be *** backwards but thats what i got
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #10 of 38 Old 02-21-2014, 04:57 PM
POWERCHOKER
Dantron's Avatar
So, does that mean the GT32 would only have more boost at the beginning of each gear shift? Which one would result in less turbo lag? Which one would result in more turbo whistle?
Dantron is offline
