My first Diesel Truck on order - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-07-2013, 10:23 AM Thread Starter
My first Diesel Truck on order Now with Pics
Ordered a 2014 F350 SC Lariat 8' bed 4x4 on 25 Sept dealer said 6-8 weeks for delivery.
Don't know if this like will work or not here is the link to the online build
Build Your 2014 Ford SuperDuty
I also order it with the camper package it was not listed in the build your own options.
Troy
TroyC is offline
post #2 of 15 Old 10-07-2013, 10:47 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Congrats on the New truck, I think you will Love it!
Make sure to read up on the 6.7L here on the Forum.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 15 Old 10-08-2013, 03:02 AM Thread Starter
Thanks,
Troy
TroyC is offline
post #4 of 15 Old 10-26-2013, 05:26 AM Thread Starter
TroyC is offline
post #5 of 15 Old 10-26-2013, 09:35 AM
ucpa111's Avatar
Quoted: 3 Post(s)
Should be a sharp looking ride. Congrats! My current truck is my first diesel...and I really enjoy it! 26,000 miles and it's a beast!
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #6 of 15 Old 10-27-2013, 05:59 AM Thread Starter
Thanks, I was sold with the test drive, night and day compared to the 6.2L
Troy
TroyC is offline
post #7 of 15 Old 10-27-2013, 06:21 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I gotta say congrats on the truck and congrats on being able to afford to build your own brand new truck. That's a spendy adventure!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 15 Old 10-27-2013, 04:59 PM
a2designs's Avatar
Quoted: 10 Post(s)
Congrats on the truck! Your 1st post said you got the 8' Bed but then the window sticker says 156" wheelbase, the 8'bed is the 172" wheelbase. You might want to double check your order is correct. Good luck on whatever you get. Remember if you take care of it, it will take care of you forever.
'16 F-350 CCLB Platinum
a2designs is offline
post #9 of 15 Old 10-27-2013, 05:01 PM
a2designs's Avatar
Quoted: 10 Post(s)
Nevermind... saw you got the SC... I am used to everyone having the crew cab configurations.
post #10 of 15 Old 10-27-2013, 06:10 PM
My dad has 83,000 on his 1.5 year old 6.7. The only issues he has had was the sensors in exhaust and the nox module. He also had an air pocket in the def tank. It was reading half full and overflowing when he went to fill it up. Another 17,000 miles and he is going the delete the dpf, and get a tune. I would love to have one when I finally wear out my 6.0, but looking under the hood on the 6.7 almost makes me want to stick with the older truck. There is a lot of crap under there!
03superstroke is offline
