OEM Headlights are Crap - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-06-2013, 06:54 PM Thread Starter
Quoted: 4 Post(s)
Whats the best upgrade availalbe for 11+ superduty's? I'd primarily like to get more and higher quality light than my stockers.
Had the opporunity to see the "Recon" style projectors (complete replacement) and they sorta sucked in my opion.
golfpineacres is offline
post #2 of 13 Old 10-06-2013, 07:09 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
The best would be doing a full projector swap which is very expensive. All of the OEM style aftermarket brands that make a direct replacement headlight like Recon, Spyder, etc. seem to be more for cosmetics rather than providing more light output. I personally wasn't impressed with the '08-10 Recon headlights. I think the light output was even less than the stockers and you can only use Recon's HIDs with their headlights or so they say. I ended up with HIDs in my stock housings. They're pretty good when they work but sometimes are problematic in cold weather.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 13 Old 10-07-2013, 03:20 AM
I changed my bulbs to PIAA and it made a huge difference
Sent from AutoGuide.com App
cooper09250 is offline
post #4 of 13 Old 10-07-2013, 03:22 AM
kirbybc12's Avatar
I'm adding some LEDs to the front of my truck, looking into a projector HID retrofit but am too scared to drill out my housings lol.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #5 of 13 Old 10-07-2013, 06:21 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We can retrofit your housings for true projection hids.
New True projection hid kits.
CT Performance, Inc. is offline
post #6 of 13 Old 10-07-2013, 06:33 AM
matty21's Avatar
Piaa is crap.
What projectors do you use? Can you fit a set of ls430's in there
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #7 of 13 Old 10-07-2013, 06:40 AM
Quoted: 3 Post(s)
We use morimoto mini bixenon projectors.
post #8 of 13 Old 10-07-2013, 06:54 AM
matty21's Avatar
The d2s 2.0? Why such a small projector in such a large housing.? Just because there so easy? Why wouldn't you go with a more elite projector. A set of rx330 afs would fit perfect. Or even better a set of ls460r bi xenons .
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #9 of 13 Old 10-07-2013, 06:59 AM
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
I have morimotos in mine, they rock. I get flashed all the time with my stock setup. I'd do projectors if it wasnt so expensive. I did fogs and headlights. Super bright and not yellow crap like OEM.
TX_TRU_STUD is offline
post #10 of 13 Old 10-07-2013, 07:33 AM
matty21's Avatar
The morimotos are by no means a crap projector but they are an entry level projector. After having used ls430's ls460's s2000's rx330afs it's hard to match those elite projectors for range and width.
Yet to be delivered
AFE stage 2 intake
matty21 is offline
