newbie 4WD switch question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-27-2013, 05:16 AM Thread Starter
I recently bought a 2011 F350 King Ranch diesel (great truck!) to tow a 5th wheel camper. My question is on the 4WD switch. If I pull it out vs. not, the only difference I see is that a truck symbol appears on the dash. Is that correct? If an explanation is in the manual, I couldn't find it.
Thanks.!
jepalmer is offline
post #2 of 3 Old 09-27-2013, 05:42 AM
WoodBoy's Avatar
If you pull it out, that engages your electronic rear differential lock. You can do this in two wheel drive or 4 wheel drive. It has a limited speed that it will not stay locked past that speed to prevent tearing up your rear end unless you buy the override from SPE
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 3 Old 09-27-2013, 06:12 AM Thread Starter
cool beans. Thanks!
jepalmer is offline
