Plastic oil pan and oil change question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-25-2013, 08:45 AM Thread Starter
I am a new guy to the 6.7. I changed my oil for the first time last night. To my surprise the oil pan is plastic as is the drain plug. Of course I am used to all metal parts.
That drain plug seems like it isn't held in there by much, just a little more than a quarter turn from off to shut.
Plus the drain hole is huge, the oil comes out like a fire hose.
Does anyone have a fix or an idea on how to prevent the oil from going everywhere when the plug is removed? I use a standard flat oil collection container. I could engineer osmething, but wanted to know if the forum had anything already established.
I went to qwikvalve.com to get their ball valve setup(I have used these in the past and they work well) but there is not one made for the 6.7.
Any help would be appreciated.
Strippedthread1 is offline
post #2 of 11 Old 09-25-2013, 12:04 PM
What year is your truck? mine has a steel oil pan!
formula29 is offline
post #3 of 11 Old 09-25-2013, 01:14 PM
sagebel's Avatar
Quoted: 10 Post(s)
'11 and early '12 trucks have a plastic pan with plastic plug. Late '12 and newer trucks have a metal pan and threaded drain plug (on the same side as the filter). SPE has put everything into a kit to change out the plastic pan with the newer metal one. Quickvalve makes a valve for the metal pan 6.7. You need to select 2013 to get it to show up on the search. Search results :: Qwik Valve
http://spediesel.com/steel-upgrade-p-1377.html
2014 CCLB 4x4 Lariat Ultimate
sagebel is offline
post #4 of 11 Old 09-25-2013, 02:05 PM
Who thought it would be a good idea to put a plastic oil pan on a diesel engine?
post #5 of 11 Old 09-25-2013, 07:18 PM
My 2011 still has the plastic oil pan with the plastic drain plug. I figured I would not change it out until she starts to leak. I started out using a regular oil drain container and what a mess it created since it would not capture the oil fast enough. I went to Home Depot and bought a 5 gallon bucket with a lid. The 5 gallon bucket works wonders and have not had a drop of oil on the garage floor since.
offroadsd is offline
post #6 of 11 Old 09-25-2013, 07:21 PM
sagebel's Avatar
Quoted: 10 Post(s)
sagebel is offline
post #7 of 11 Old 09-26-2013, 03:08 AM Thread Starter
Thanks for the replies. My truck is a '12 F350 Lariat.
post #8 of 11 Old 09-26-2013, 03:16 AM
WEWILLE's Avatar
Take an old1 gallon jug and cut it up in such a way that it "guides" the oil into the pan. I can show you a picture of what I made. The first one we did at the dealer the tech working on it pulled the plug and went straight to the shower!
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #9 of 11 Old 10-19-2013, 10:39 AM
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
Just wanted to add to this thread.
I was looking at my water separator today and took a pic of the oil pan and plug. I have a 13 and it does appear to be a metal pan but no more yellow oil plug. Anyone else with a 13 have the same? I assume so. I wonder why they got rid of it. Anyone with a 14 have the yellow plug back or same as mine?
TX_TRU_STUD is offline
post #10 of 11 Old 10-19-2013, 11:16 PM
mcd
Use a 5 gal bucket to drain your old oil in. Will have to trim the top a little (unless you are lifted), but it will slide right under the pan. 1/4 turn on the plug and let her buck. Did not spill a drop last change.
mcd is offline
