Top Speed 95MPH????? Why??? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-17-2013, 10:48 AM Thread Starter
2013 6.7 tops out at 95MPH, how can I override this? Is there a trick to do it or do I need to have the dealer do it?
Please don't ask why I want to do this, it is a personal choice. I could run 120 in my old 7.3.
I should control my speed, not Ford!
BIGBADCANE is offline
post #2 of 23 Old 09-17-2013, 10:57 AM
Raul@Stealth Automotive's Avatar
get a tuner......
Raul@Stealth Automotive is offline
post #3 of 23 Old 09-17-2013, 12:03 PM
what raul said you will need a tuner to remove the speed limiter and also make sure your tires can handle the speeds. You dont want to have a catastrophic tire failure at those speeds. Im pretty sure that 6.7 will do better then 120 depending on what gears your running
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
post #4 of 23 Old 09-18-2013, 04:21 AM
6.0f250firstcar's Avatar
It's because of the tires and driveline. Also, from a safety perspective, a 100+ mph 8,000 lb hunk of metal could do down serious damage.
Ryan
6.0f250firstcar is offline
post #5 of 23 Old 09-18-2013, 06:11 AM
WoodBoy's Avatar
Doesn't all newer trucks limit speed between 95-100 with the exception of maybe a couple
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 23 Old 09-18-2013, 06:31 AM
get a tuner. Also, Ford puts that on there so they don't get sued by some idiot that got in an accident because he was going faster then the vehicle is setup to do safely and wants easy money.
vdrsnk04 is offline
post #7 of 23 Old 09-18-2013, 07:27 AM
Ram is 105. Chevy is 100. Ford is 95.
Ryan
post #8 of 23 Old 09-19-2013, 04:44 AM Thread Starter
Thanks for the input, I will get a tuner.
post #9 of 23 Old 09-19-2013, 05:41 AM
2013F250Tank's Avatar
When installing programmer it will ask if you want to adjust it. Set mine on 200. lol No it will never see it.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #10 of 23 Old 09-19-2013, 11:11 AM
Bryce18's Avatar
Quoted: 19 Post(s)
Mine has seen 135mph once or twice. And not for very long since I don't have tires rated for that speed
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
