Edge Insight CTS set up - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-17-2013, 11:16 AM Thread Starter
Hello all,
I just installed an Insight CTS in my 2013 F350, and was wondering what PIDs I should monitor. I like the option of setting an alarm for certain PIDs, but I don't know what levels to set the alarm(s) at. Also, from what I understand that in stock form there is no way to monitor per-turbo EGTs. Is this even a parameter I need to worry about? The truck is primarily a second vehicle used to tow my 8k lb 5th wheel.
I want to give Edge Products a quick shout about their customer service. I had a problem updating my CTS where it suddenly refused to power up. I received the monitor back two days after they received it, and it worked perfectly. Couldn't be happier with how this problem was resolved.
Thanks,
Marc
Tcop143 is offline
post #2 of 7 Old 09-17-2013, 07:52 PM
Quoted: 14 Post(s)
I monitor my EGT1 and EGT4. Both of those are down stream of the turbo. You are correct, there is no oem sensor pre turbo. You will see the temps in the EGT4 go up to around 1100-1200F during active regen and it stays hot for a few minutes after the regen ends.
I also display my Soot %
Soot % will trigger a regen usually around 2.75% It gives me a little idea of when the next regen is coming
I also show my Voltage and ECT since the dash command center show Oil temp and Transmission temp
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #3 of 7 Old 09-18-2013, 09:53 AM
ohman_stm's Avatar
Ditto what PH stated for PIDS. I have the CS.
Not sure why Ford doesn't add a pre-turbo sensor, makes no sense to me. In my stock application, I gauge the EGT1 PID, and normally wait until it's well below 400 degrees before I shut the truck off, unless of course, I have my wife with me, and she gets *impatient*.
2012 F350 CC LARIAT LONG BED 6.7L
ohman_stm is offline
post #4 of 7 Old 09-20-2013, 08:46 PM Thread Starter
Awesome, thanks for the replies guys.
Tcop143 is offline
post #5 of 7 Old 11-26-2013, 09:22 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Painted Horse, where did you route the cable from the OBD11 port to the Module? Did you tuck it behind the seal running up the driver side door?
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 7 Old 11-26-2013, 11:05 AM
If you pop the little side access panel off on the side of the dash it's easy it route it down to the OBD port.
On the top site you can just put it between the dash and pillar
savage250 is offline
post #7 of 7 Old 11-26-2013, 11:11 AM
Quoted: 4 Post(s)
Thanks, I will try it out.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
