Snow Plow Mount Questions - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-06-2013, 04:04 AM Thread Starter
I am going to be putting a Boss RT3 Mount on my 13 F-350. I have seen various ways of mounting but what does everyone recommend. Do you cut out the stock valence...or will it clear with a 2WD one? Would anyone happen to have any pictures? Thanks guys!
Hellersharleys is offline
post #2 of 14 Old 09-06-2013, 05:49 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Subscribed just out of curiosity.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 14 Old 09-06-2013, 06:56 AM
PowerStrokePete's Avatar
I cut holes in the stock 4wd valance, but then when I was plowing, it hit some snow and ripped off. I just never put it back on.
2011 F-250 SCLB XLT 6.7 Powerstroke
-H&S Minimaxx
-H&S EGR Delete
-Flo-Pro 5" exhaust
-Airaid intake
-Fisher 8.5' Xtreme V SS
-OUO traction Bars
-Dick Cepek DC-2, 35x12.5R18 Toyo A/T II
PowerStrokePete is offline
post #4 of 14 Old 09-06-2013, 07:35 AM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
My cousin cut his valence on his truck for his Boss plow. Basically, there's two rectangular chunks cut out of the valence about 12" apart. Seems to work well when the plow's on but in the offseason, looks dumb if you didn't know there was a plow there during the winter.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #5 of 14 Old 09-06-2013, 06:22 PM
Second on how it looks like crap when the plow is disconnected.
Sent from AutoGuide.com App
-H&S Minimaxx
-H&S EGR Delete
-Flo-Pro 5" exhaust
-Airaid intake
-OUO traction Bars
post #6 of 14 Old 09-06-2013, 06:29 PM
superstack's Avatar
My old boss has an 11' with a western plow. When we put the mount on the truck we just took it off. Plowin with a truck tends to rip low hanging things off and that chunk of plastic couldn't get much lower.
superstack is offline
post #7 of 14 Old 09-06-2013, 07:08 PM
kirbybc12's Avatar
Just take off the valance, I think trucks with the cut outs look trashy.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #8 of 14 Old 09-06-2013, 07:11 PM
That's the valance that ripped off while plowing. You can see how the pockets they cut out while installing the plow mounts look.
-H&S Minimaxx
-H&S EGR Delete
-Flo-Pro 5" exhaust
-Airaid intake
-OUO traction Bars
post #9 of 14 Old 09-10-2013, 08:28 AM
Summitman's Avatar
Does anyone have any pictures of the plow installed??
Also I'm wondering what all hangs off the truck for the world to see in the summer when the plow is in storage.
2001 F250 7.3 Lariat
2015 F350 6.7 Platinum
2015 F150 3.5 Platinum
Summitman is offline
post #10 of 14 Old 09-10-2013, 08:46 AM
kirbybc12's Avatar
Basically if you take the brackets off all you will see is the crossmember and the mounting frames for the brackets like this:
You won't see the two front pieces if you take them off, the upper part is behind the bumper. I believe this is a dodge frame but the front is identical.
I actually saw a truck today that had a hole in the valance that only fit the brackets, wasn't cut all the way down. It looked pretty decent compared to the butcher jobs some of these install clowns do.
2.5" Carli Commuter
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
