U0074 & U0106 codes - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-03-2013, 05:32 PM Thread Starter
jcatchem's Avatar
U0074 & U0106 codes
Like the title says I have 2 codes U0074 & U0106 GPCM communications lost. has anyone had this problem and if so what was the fix. Thanks for any help.
Jeff
jcatchem is offline
post #2 of 10 Old 12-18-2013, 07:43 AM
Any luck? My 2011 threw same codes yesterday.
cmallow is offline
post #3 of 10 Old 12-18-2013, 08:08 AM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
What do you guys have done to your trucks or are you guys stock
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #4 of 10 Old 12-18-2013, 08:10 AM
Hs mini maxx
dpf delete
Afe intake
Mine threw codes after starting at 5 degrees and has done it 3 times while air temp around 10-15
Not sure if it has anything to do with temp or not
cmallow is offline
post #5 of 10 Old 12-18-2013, 08:24 PM
Carli'd6.7's Avatar
First id call H&S and see if they have had any issues with those codes in their software. Second check your batteries the Glow plug control pull a lot of juice when cold and if all else fails replace your glow plug control module, try plugging your truck in and see if that changes anything , its worth a shot .
post #6 of 10 Old 12-19-2013, 07:01 AM
Thanks for the help we determined it is the glow plug module $180.
cmallow is offline
post #7 of 10 Old 01-24-2015, 09:22 AM
I have a 2011 6.7 and I just received U0074 and U0407 codes. Is the glow plug control module difficult to replace? Would it be easier to just have the dealer replace this module?
Thank you,
offroadsd is offline
post #8 of 10 Old 03-19-2015, 04:07 AM
Did you guys ever figure out what the problem was. My truck is throwing the same codes. Mine is a 2011 deleted with a spartan programmer. I replaced the glow plug module once already. Also where did you guys order your glow plug module from?
Thanks
Ben
StrokeWang is offline
post #9 of 10 Old 04-14-2016, 04:51 AM
Make sure the NOS Modules are unplugged. I had the same issue on my 2015 F-350 and was told to make sure the modules were uplugged. Sure as can be that fixed the issue. On the 2015 there are 2 modules and they are located on the passenger side frame rail, I assume the olders ones are the same.
KeithL is offline
post #10 of 10 Old 03-12-2017, 07:05 PM
Quoted: 10 Post(s)
Thanks for the help keithl. Just had this happen to my 15 tonight. Had one nox module removed but I guess I left the front one on the frame. Unplugged the module and replaced fuse #36 under the hood and all is good again.
2015 f350 lariat ultimate
5" Flo pro
Egr blocker plates
Ndash sotf
Nl stage 2 intake
cappa is offline
