Jumping gasser battery with a diesel? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-29-2013, 06:14 AM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 51 Post(s)
I have an old truck whose battery is dead and I need to jump it. I believe the batteries in the 6.7 are in series so it shouldn't matter what battery I use to jump the gasser should it?
What is the process to jump a single gasser battery with a diesel truck or is it the same as a gasser to gasser?
TX_TRU_STUD is offline
post #2 of 7 Old 08-29-2013, 06:46 AM
Randy_270's Avatar
Quoted: 2 Post(s)
When I jump started my girlfriends car I just went off one single battery like you would with a gasser and it worked perfectly
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #3 of 7 Old 08-29-2013, 09:16 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
I have a quick jumper setup which is tied to one battery and grounded so you should be able to use one battery with no issues.
DSL_PWR is offline
post #4 of 7 Old 08-29-2013, 09:32 AM Thread Starter
Quoted: 51 Post(s)
So from what yall are saying, I can just pick a battery on my 6.7 and then connect it like normal to the old truck? Sounds good to me.
The 6.7's batteries are in series, correct? Not parallel?
post #5 of 7 Old 08-29-2013, 10:31 AM
Davey~do's Avatar
It sounds like you have the right idea, but are using the wrong term.
A series circuit would require the negative terminal of the first battery to be hooked to the positive terminal of the second battery. This allows for only one path of electron flow, and doubles the system voltage, to 24V nominal.
A parallel circuit allows multiple paths of electron flow. The positive terminals of both batteries are hooked to the same source, and both negative terminals are to ground. This system keeps the voltage at 12V nominal.
Either way, long story short; the system should be a parallel 12V, and you can jump just like any other vehicle, from either battery.
Davey~do is offline
post #6 of 7 Old 08-30-2013, 04:52 AM
RAINEY's Avatar
There is a lead battery. I forget which one off the top of my head. It is the one that has the most stuff near the connectors.
Jason
2012 F350 SRW Bought new with 550 miles on it in July 2013
RAINEY is offline
post #7 of 7 Old 08-30-2013, 05:13 AM
Snake's Avatar
Quoted: 46 Post(s)
Correct
Great explanation, and easy to understand. Thanks for saving me a lot of typing.
There isn't a lead battery, or a primary/secondary arrangement, when batteries are connected in parallel. It's like having a giant 12v battery with multiple posts (aka, positive and negative terminals)
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
