Is the Torq 2.2 the only thing available? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-24-2013, 09:15 PM Thread Starter
Black2011SD's Avatar
Is the Torq 2.2 the only tuner available for the 6.7 that won't leave a thumb print or a trace it was ever on the truck?
Black2011SD is offline
post #2 of 10 Old 08-26-2013, 12:16 PM
Quoted: 18 Post(s)
What makes you think it doesn't?
The computer is going to record any turbo boost and several other parameters.
So if you have readings that show high boost, they will know you had a tuner of some sort was on the engine.
The Torq may not leave a message that it was installed, I have to believe it will push many parameters higher than the OEM computer does, making it easy for the techs to know something was installed that modified the factory programing.
Does it matter to the warranty gods if they know you had a programmer installed or just that certain PIDs all show you were over spec?
Unless the Torq erases all the Engine codes from memory, Somebody will be able to know a tuner was involved. And if it does erase all the codes. Then I suspect the absence of codes is as much a flag as having too high of values.
Most folks are reported good success with their tuners. I don't see a problem with the techs being able to tell. If you push it too hard and break something, then it should be your money and not the warranty departments
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #3 of 10 Old 08-26-2013, 12:27 PM Thread Starter
Yeah...I figured it was too good to be true....
post #4 of 10 Old 08-26-2013, 01:28 PM
broncojason's Avatar
The Torq 2.2 will not change ur boost pressure at all. It only boosts ur fuel rail pressure, and does not show up on the PCM. There are no warranty concerns whatsoever... This is just a fuel module, and not actually a "tuner"
This came straight from Eric at Innovative.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #5 of 10 Old 08-26-2013, 02:56 PM
Quoted: 4 Post(s)
Kind of like a diablo sport power puck? I used to run one on a cummins. Smoked like crazy. I imagine it would clog a DPF pretty quick. Maybe I'm wrong.
Sent from AutoGuide.com App
Deerhunter4 is offline
post #6 of 10 Old 08-26-2013, 03:04 PM
I ran it for 2.5 months, and didn't see anymore regens than normal... Seems like every 500 miles or so.
post #7 of 10 Old 08-26-2013, 03:12 PM
Quoted: 4 Post(s)
See any mileage improvements?
post #8 of 10 Old 08-26-2013, 03:29 PM
Yes. When I ran stock tires, I easily saw numbers as good as 22.5 hand calculated, but that went all to HAIL when I put on my Nittos
post #9 of 10 Old 08-26-2013, 03:41 PM
Quoted: 4 Post(s)
Ok. Cool. Thanks for the response.
post #10 of 10 Old 08-26-2013, 03:45 PM
Keep in mind that I was driving 54-56 mph, and trying for maximum mileage.
When I drove normal, it was probably closer 20mpg.
