With a 2.5 leveling spacers how much rear block do I need? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-17-2013, 12:16 PM Thread Starter
Looking a buying a leveling kit from somebody. It's the rubber style that goes on top of spring. He has 4" blocks with it and said it was on a f350 and was level. Will it make my 2011 f250 level or rear high
2005 f250
Arp headstuds
Egr delete
4" straight pipe
Sct tuner
8" with 37s
Coolant filter
Elc coolant
Seand717 is offline
post #2 of 10 Old 08-17-2013, 12:47 PM
alaskan155's Avatar
Quoted: 65 Post(s)
rear low
f250 has a factory 2" rear block
f350 has a factory 4" rear block
that assuming he measured it and it was exactly level or eye balled it(be within 2")
just measure from ground to fender lip on your truck and subtract the front from the rear, my 02 f250 is 2" difference from the factory,
since the 11 are coil spring, measure the spacers, they are a 1:1 lift, so a 2" spacer will net 2" of lift on the front
edit*
just saw yours was a 11, not a 05 like the sig, so the rear blocks may not follow that generation
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 10 Old 08-17-2013, 01:04 PM
BIG Laing's Avatar
You need an f350 block to sit level. Also you need to get an adjustable track bar and new shocks.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 10 Old 08-17-2013, 01:35 PM
broncojason's Avatar
Yes, that combination will get u pretty close to a 2" lift, and sit level, but as mentioned, you'll need shocks, and adjustable track bar, or drop track bar bracket.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #5 of 10 Old 08-17-2013, 02:51 PM
i put the readylift 5" block on my f250 and it made it level
Bopper is offline
post #6 of 10 Old 08-17-2013, 05:41 PM
richiee23's Avatar
I just put 2 inch kit on the front of my 2013 f350 and it sits level to me. I'm thinking about changing my f350 block to a 4.5 top gunz block. Should give me about 3/4 of a inch more in the rear.
richiee23 is offline
post #7 of 10 Old 08-18-2013, 06:52 PM
KAKnight's Avatar
I just put a carli 2.5" leveling kit in the front of my 2011 250 and then a readylift 4" block in the rear. It has a very slight rake to it (front lower than rear) and it was exactly what I was looking to do. I am also installing a wireless ride rite airbag system in the rear this next weekend
Sent from AutoGuide.com App
KAKnight is offline
post #8 of 10 Old 08-19-2013, 02:59 AM
richiee23's Avatar
I parked mine beside a new f350 at the dealer and the rear is lower than the new f350. I guess I have one of the lower sitting f350 in the rear.
post #9 of 10 Old 08-19-2013, 06:15 PM
i have a set of ready lift rear blocks that i put in and then took out right away....2011-2013 Ford F250 Super Duty 4" Rear Block Kit i upgraded to heavier springs but needed OEM blocks for correct ride height. i just have blocks, no u-bolts make me an offer please email me at dieseldawg05@yahoo.com
2012 F-250 (SHOULD HAVE BEEN AN F-350) 6.7 REG. CAB XL TRIM KNAPHEIDE SERVICE BODY BOSS 8 FT PLOW COMPANY TRUCK NOT ALLOWED TO MOD......YET
DIESELDAWG05 is offline
post #10 of 10 Old 10-06-2013, 12:11 PM
colonel angus's Avatar
Quoted: 2 Post(s)
It won't hurt to add the machined 1" spacer as long as it has it's own stud and hole for the spring pack bolt.
You don't want to stack 2" + blocks.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
