Getting new engine - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-10-2013, 08:20 PM Thread Starter
SCE Construction's Avatar
Getting new engine
So as the tittle states ford tells me I get a new engine soon engine has 30k on it as is and at 11k it had a valve issue and I was one of the Idaho trucks having this problem ford fixed my valves at 11k but put me on the list for new engine.
That being said I recently bought the extended warranty to 100k it was worth the money to me. I usually trade in every few years and get a new truck but as the miles add up the truck runs better so i might just keep it till that 90k mark! i tow very frequently (construction & horses) and the truck is stock. I hand add my mpg and average 15.7 oem daily/towing etc. I know everyone says dpf delete but I can't do that. So intake time.
My thoughts at the moment are should i get a s&b intake my dealer and tech are pretty cool, but against the dpf delete. Or should I wait till the new engine is put in?
Advice / criticism etc welcome
Thanks
____________________________________________
2015 F350 Platinum
SCE Construction is offline
post #2 of 9 Old 08-10-2013, 08:48 PM
Go ahead and get the intake. Then use it on the new engine. You'll love it . They won't revoke your warrantee or new engine for an air filter
Superdutymatrix is offline
post #3 of 9 Old 08-10-2013, 08:53 PM Thread Starter
Anyone else had the valve issue? I also am looking for an additional oem exhaust tip if anyone has one
post #4 of 9 Old 08-10-2013, 08:55 PM
A few did but ford has fixed that issue in the 13's
post #5 of 9 Old 08-10-2013, 09:10 PM Thread Starter
Ok thanks.
2015 F350 Platinum
post #6 of 9 Old 08-11-2013, 07:34 AM
there is a TSB out or replacing the l/s exhaust valves on all M.Y. (2011-2013) 6.7L engines..
poormanscat is offline
post #7 of 9 Old 08-11-2013, 08:59 PM
<<---"Shadow"---
sea71's Avatar
Ford just replaced my 2011 engine with a new one. Dropped valve driver side. Long block from Detroit. !500 miles on the engine now. Dealer said Ford said was newest technology, and was same as 13s. I dont really know. Just glad they replaced it.
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #8 of 9 Old 08-12-2013, 08:51 AM
psi_2_high's Avatar
Does the intake, make any at all small HP increase, or make the turbo's spool a little louder? on a stock truck?
2011 F350 FX4, Lariat, Recon Lights, more to come!!
2005 F250 ,Garret PowerMaxx, Studded, Bulletproof EGR Delete, 12" Rize quad link / King Coils / King Ress shocks, 4.56 Gears, Full HD interior, Straight Piped, Toyo 40/15.50/22 Fuel Hostage Deep Rim. And a ton more stuff i forgot!!
psi_2_high is offline
post #9 of 9 Old 08-12-2013, 06:10 PM
I just installed the S&B, no horse power to notice, I can hear the turbo a little better, with the windows down. Have no idea about fuel mileage, I don't think it had any affect.
The truck now has a nice intake growl to it, you can tell the intake was added. It is a quality set up. The motor sounds great with this intake and stock exhaust.
svilla is offline
