F450 ?? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-04-2013, 07:12 PM Thread Starter
F450 ??
so looking and am gonna come to the darkside and buy a ford for sure but now im trying to decide between a 450 or a 350?? what are the biggest differences? is it just the payload and towing or is there different hp/torque in the 450 etc etc. i need at minimum a 1 ton but thinking a 450 would do just as good. how the ride differences and so on thanks in advance.
2011 F350 DRW lariat Spartan tuned, 4" straight piped exhaust,afe stage 2 CAI,SDP egr delete and more coming
Sold 12 ram 2500 and dont miss it!!!
E99 F350 7.3L parts on the way
skinnysfd is offline
post #2 of 14 Old 08-04-2013, 07:16 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I am a firm believer of overkill is normally just about right. If a 350 is the minimum of what you need and you have the chance to get a 450, Id say go for the 450. Work your equipment a little easier and itll last longer.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 14 Old 08-04-2013, 07:16 PM
Quoted: 2 Post(s)
450 has less power, slower spool up as it doesn't have a vgt turbo, but more gear options
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #4 of 14 Old 08-04-2013, 07:17 PM Thread Starter
actually has less power? wow why would that be
post #5 of 14 Old 08-04-2013, 07:37 PM
Quoted: 2 Post(s)
Detuned for more duty cycle
jcain is offline
post #6 of 14 Old 08-04-2013, 07:42 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Because it has more weight ratings, it has less power to save the motor.
How much are you going to load it up? If it's max every day all day, F550.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 14 Old 08-04-2013, 07:45 PM Thread Starter
it wont be max all the time but i do pukk a 53' gooseneck quite a bit and usually have my extendable forklift on it. also pull my rough terrain scissor lift, skidloaders, and metal buildings on em. so really dont need a 450 was just wondering about big differences. And also getting into a truck that doesnt go through front ends every 10,000 miles damn rams!!
post #8 of 14 Old 08-04-2013, 07:46 PM
6.0f250firstcar's Avatar
IIRC, it is only the C&C f450 trucks that are detuned.
Ryan
6.0f250firstcar is offline
post #9 of 14 Old 08-04-2013, 07:47 PM Thread Starter
ok so the non c&c is the same as the 350?
post #10 of 14 Old 08-04-2013, 07:48 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Yea, forgot that.
If you're doing this for business, better to be within legal ratings.
450s have wider front axles I think, bigger brakes, different gear ratios for rear diff, bigger wheels.
4R100, 2wd
330,000 + miles
jesilvas is offline
