Cab Clearance Light Plug - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-04-2013, 12:13 PM Thread Starter
AngryBird's Avatar
Hey Guys. I went down to the Local Line-X shop and had them install recon cab lights on my F250. When I was installing the upfitter switches today, I noticed that they tapped the parking light signal wire (28ga by the looks of it) that comes out of the back of the factory headlight switch. I know the recons are LED but I'm not comfortable pulling power out of a signal wire for them.
Does anyone know where the factory cab light plug is on a 2013 F250 Lariat? (picture or diagram would be great) I've done a lot of searching and cant find anything on the 6.7L model year trucks. Lots on the 7.3, 6.0, and 6.4.
Thanks!
2013 6.7L F250 Screw FX4
AngryBird is offline
post #2 of 8 Old 08-04-2013, 07:53 PM
dodge_dbag's Avatar
theres a harness under the dash it's hard to get to. tomorrow i can take a pic
08 f450 xlt fx4
11 f350 king ranch fx4
12 f250 lariat fx4
dodge_dbag is offline
post #3 of 8 Old 08-04-2013, 08:01 PM
dodge_dbag's Avatar
went and snapped you a pic. dealership gave me the wrong harness and i had to tap into the power source for the parking lights.
08 f450 xlt fx4
12 f250 lariat fx4
post #4 of 8 Old 08-04-2013, 08:06 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Should be in the passenger side kick panel. If its not there then its the driver side. I'm pretty sure it's passenger though. It should be a plug with only 2 wires going to it. Test it to be sure though before. I have installed a few sets, I'm doing a 6.4 this coming weekend.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 8 Old 08-04-2013, 08:07 PM
dodge_dbag's Avatar
6.7s have them under the dash by the firewall on the drivers side.
08 f450 xlt fx4
12 f250 lariat fx4
post #6 of 8 Old 08-05-2013, 06:32 AM Thread Starter
AngryBird's Avatar
Thanks dodge_dbag! I recognize that big harness plug to the left so I know right were to look now. I think its going to be really hard to get to so I may end up trying to tap into the harness behind the kick plate and grab on of the wires that runs to the rear of the truck for the taillights or to the mirror clearance lights.
post #7 of 8 Old 08-06-2013, 06:13 AM Thread Starter
AngryBird's Avatar
I found a yellow wire with a green stripe in the harness that runs behind the driver side kick plate that responds the same as the parking light. I tapped into that to run the cab lights and now they are a lot brighter! I can't believe that guy at the shop tapped into a signal wire behind the light switch. I guess he is just used to older trucks where the switches used to carry power. Thanks for your help again.
post #8 of 8 Old 08-06-2013, 09:09 AM
dodge_dbag's Avatar
that's good that you got your lights working better
08 f450 xlt fx4
12 f250 lariat fx4
