Oil idiot light? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-27-2013, 06:54 PM Thread Starter
daystrom's Avatar
Quoted: 8 Post(s)
Oil idiot light?
Do these trucks have low oil pressure lights? The manual seems to indicate that there is a light on the speedo cluster but I have never seen it when starting the truck.
Just don't know if it's there but burned out or does it only show up on the information screen when low?
Todd
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
post #2 of 8 Old 07-28-2013, 12:05 PM
I didn't see mine either during startup. I looked in the 2012 owner's manual and found there is also an "Oil Diluted" light. I have no idea what that looks like either. It isn't even mentioned in the diesel supplement.
JohnDS is offline
post #3 of 8 Old 07-28-2013, 12:10 PM
Quoted: 2 Post(s)
It probably comes on when it senses a problem.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 8 Old 07-28-2013, 02:57 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
You all have the screen on the dash so I'm sure it's programmed to come up on the screen and go I to limp mode if the problem occurs.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 8 Old 07-28-2013, 05:06 PM Thread Starter
daystrom's Avatar
Quoted: 8 Post(s)
Thanks for all the info. Would have thought that I'd at least get some sort of idiot light at pre-start.
Todd
daystrom is offline
post #6 of 8 Old 07-28-2013, 06:55 PM
Quoted: 2 Post(s)
x222222222
wreedPS is offline
post #7 of 8 Old 08-02-2013, 02:07 PM
Traveling Man's Avatar
Only truck I have ever owned that didn't have a oil pressure gauge. It certainly would be know how much oil pressure these motors produce.
Traveling Man is offline
post #8 of 8 Old 08-02-2013, 03:51 PM
My light will come on after about 10-15 seconds when I turn the key to the on position without starting the truck. It shows a big message in the center cluster info screen.
2011 F-350 CC LB SRW Larriet 6.7 PSD with a limited edition rear end bounce @ 43 mph.
thom12 is offline
