New truck...A few Questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-27-2013, 06:52 AM Thread Starter
Quoted: 4 Post(s)
Picked up a 2013 XLT Crewcab FX4 last week. The next day I took it on vacation and I already have 1300 miles on it. So far it's great. Good ride and good mileage.
My questions are maintenance related. What oil are you guys running. I get my first change for free from the dealer but I'll do my own after that. I'm think of running the Rotella T5 10W-30. According to the diesel supplement in the owners manual that should be acceptable.
My other question is about the coolant check that is required. How involved are these checks and where do you get the kits?
Thanks for the help.
Sent from AutoGuide.com App
Deerhunter4 is offline
post #2 of 9 Old 07-27-2013, 10:08 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Congrats on your new tuck!
I use motorcraft 10-w-30. The test strips are Ford Rotunda or equivalent. Make sure you test both primary and secondary cooling systems and take samples from the drain valves, not from the Degus bottles.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 9 Old 07-27-2013, 10:47 AM Thread Starter
Quoted: 4 Post(s)
Thanks for the response. Wish I could get Motorcraft oil somewhere besides the dealership. Their prices are high.
post #4 of 9 Old 07-27-2013, 01:19 PM
ucpa111's Avatar
Quoted: 3 Post(s)
Rotella T6. Send my oil for analysis and it's looking good. 21,000 on the truck
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #5 of 9 Old 07-28-2013, 05:48 AM
RAINEY's Avatar
The Motorcraft oil is just a ConocoPhillips oil. It's nothing special. You can buy plenty of other good oils out there.
Jason
2012 F350 SRW Bought new with 550 miles on it in July 2013
RAINEY is offline
post #6 of 9 Old 07-28-2013, 06:30 AM Thread Starter
Quoted: 4 Post(s)
Yea I'll probably use the Rotella. I can get it fairly cheap at Wal Mart.
post #7 of 9 Old 07-28-2013, 03:07 PM
Quoted: 4 Post(s)
^^^Do you plan to use Synthetic or Conventional?
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #8 of 9 Old 07-28-2013, 07:19 PM Thread Starter
Quoted: 4 Post(s)
I think the T5 10W-30 is semi-synthetic. I think the t6 5W-40 is full synthetic. I'm leaning towards the T5 right now but I'm not sure yet.
post #9 of 9 Old 07-28-2013, 07:27 PM
ngaraiderman's Avatar
Walmart has motorcraft oil
ngaraiderman is offline
