6.7 coolant ? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-24-2013, 06:54 PM Thread Starter
rayray offroad's Avatar
6.7 coolant ?
Hey guys I have a 2011 350 and my coolant has turned blackish compared to it normal pink/orange color. Dose anyone have an answer for this or is this just normal for these truck
2011 F350 4X4 cc king ranch
2004 f350 fx4 cc edge cts insight, stright piped.... SOLD!!!!!!!
running
rayray offroad is offline
post #2 of 15 Old 07-25-2013, 02:15 AM
you need to get a set of test strips and the additive
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #3 of 15 Old 07-25-2013, 02:21 AM Thread Starter
Ok but it did it once before brought it to the stealer and they said its fine. I didn't believe them so I flushed the coolant and put new motorcraft stuff in. 1,000 miles later its black again
running
post #4 of 15 Old 07-25-2013, 09:50 AM
Black? You definitely have a problem! The owner's manual says the coolant must remain clear (p. 308):
During normal vehicle operation, the engine coolant may change color from orange to pink or light red. As long as the engine coolant is clear and uncontaminated, this color change does not indicate the engine coolant has degraded nor does it require the engine coolant to be drained, the system to be flushed, or the engine coolant to be replaced.
I'd give your dealer another chance--point this passage out to them and see what they say--but I'm very surprised at their first response if your coolant really is turning black.
2013 F-250 Diesel 4X4 Lariat Crew Cab SRW Short Bed FX-4 with 3.31 rear
sobiloff is offline
post #5 of 15 Old 07-25-2013, 01:35 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Subscribed.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 15 Old 07-25-2013, 02:00 PM
greygearhead's Avatar
The only thing in the engine that can make the coolant black it the oil. And as you would know, that ain't good! Head gasket???
2012 F350 2wd srw 8' Lariat 6.7
2004 Ranger FX4 Level II
2008 Mustang Bullitt dhg
greygearhead is offline
post #7 of 15 Old 07-25-2013, 03:46 PM
Quoted: 18 Post(s)
Is the Degas bottle showing the black or has the actual coolant turned black? The plastic bottles have a tendency to look stained making the coolant look dark in color when viewed in the plastic bottle.
The coolant doesn't have to stay orange. It will vary in color from pale orange to almost a dark red.
But black, especially with any kind of an oily sheen, would be bad.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #8 of 15 Old 07-25-2013, 04:05 PM
unfortnately thats not true.
Antifreeze can burn when exposed to high temperatures. These high temperatures are introduced via combustion gasses leaking into the cooling system. This can come from a cyliner head gasket, but typically you will know this due to the degas bottle over pressuring and blowing out coolant.
Another area for it to be introduced with the over pressurization of the cooling system is for the EGR cooler to have a small crack or faulty solder.
A lab can test your antifreeze for the presence of combustion gas contamination.
poormanscat is offline
post #9 of 15 Old 08-06-2013, 04:32 PM Thread Starter
sorry guys i had a lot go on in my life the past two weeks and haven't gotten a chance to get back.
ok so maybe it is dark red but still its changed color quick. one other think ive noticed is my engine oil temps when driving down the highway at 65-70 mph my oil temp is 210* i dont every remember it being that high.
i would bring to dealer but i have done the delete and am running h&s on tow tune
running
post #10 of 15 Old 08-06-2013, 08:58 PM
Quoted: 18 Post(s)
It's not uncommon to see your oil temps hit 242 when the engine is working hard.
So don't worry about the 210 its within reason
The 6.7L uses the oil to help cool the engine. It shoots a jet of oil at the bottom of each piston on each stroke to help cool the piston. So it will run hotter than previous engines
