Transfer Flow question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-21-2013, 02:03 PM Thread Starter
I just purchased a '13 XLT F350 cc/lb FX4, and I'd like to install my 50 gallon Transfer Flow aux tank. Will I lose my distance-to-empty feature, or can my dealer reprogram the computer for the new capacity? Any other issues you all know of that might complicate this install?
Thanks,
Marc
Tcop143 is offline
post #2 of 10 Old 07-21-2013, 03:32 PM
factoryflood's Avatar
You'll have to get your dealer to reprogram your trucks computer for the added fuel capacity.
If you don't, your fuel gauge won't work properly and your miles to empty won't work properly.
2012 F350SRW CCSB
H&S Mini Maxx with MCC, Spartan with war hammer(FOR SALE), 5" down pipe back exhaust, AFE Stg 2 Cold Air Intake, 6k 55w HIDS, Eagle Alloys 014 20x9 0 offset wheels, 35x12.50R20 Toyo Open Country AT2 Xtreme, UWS toolbox
Inside- Pioneer AVH3200BT, 2 Kicker CVT 12's, Kicker ZX1000, 4 gague wiring, Custom sub box, 20% tint all the way around
factoryflood is offline
post #3 of 10 Old 07-22-2013, 06:02 AM
I have a 60 gallon aux tank in my bed. This tank has a float gauge on it so I can tell how much is in it. It drops the fuel into the truck tank filler tube about 8-10 inches from the cap. It has a float assembly that shuts off fuel transfer if truck tank gets full. There is a ball**** shut off at the aux tank if I don't want to refill the truck tank.
When I am driving I leave the ball**** open and fuel drops into the truck tank as needed. The fuel gauge stays on full because the tank stays full. Once the aux tank is empty, the truck gauge starts falling as fuel is used. I never had to reprogram anything it just works.
The distance to empty only works right if I close the ball**** and stop fuel from transferring. The distance to empty is calculated from the fuel gauge level and not by how much fuel is used.
This system works very nicely and my range is about 650 miles when I pull my RV. The last 37 gallons are only in the truck tank so the gauge is right on as is the distance to empty computer once the aux is empty.
Even if you do not have a gauge for the aux tank, you will still see you are low long before you run out. It would be like you don't have the aux tank and just see the truck tank after the aux empties.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #4 of 10 Old 07-23-2013, 06:35 PM
It won't work properly anyways. Say the fuel level sender outputs 0-5V. 0 is empty, 5V is full. With a different sized tank 4.2V is going to be a lot more than 4.2V on the stock tank.
With the aux tank in the bed feeding the main tank, your fuel level sender is going to send 5V 100% of the time until the aux tank is depleted.
IMO if you haven't purchased it already, get something other than a transferflow. There are other brands that make comparable or better quality tanks for the same or less money.
2012 F350 Lariat SRW CCSB 4x4 - Vermillion Red
Icon 7" Lift, BMF Novakane, 37x13.5x22 Toyo MT, MBRP Filter Back, 2WD Chin Spoiler, RDS 150 Gallon Tank
turboryan is offline
post #5 of 10 Old 07-23-2013, 07:08 PM
I replaced my oem with a titan tank and the fuel level works but the miles to empty acts as if it did prior to the tank.. so basically whatever it reads you can double it
Bopper is offline
post #6 of 10 Old 07-24-2013, 01:14 PM
lwg
If your talking about the replacement tanks the dealer can reprogram for it. I went to the Transfer Flow 50 gallon on my truck and the dealer reprogrammed it to read correctly. Now I can drive 800+ miles between fill-ups or about 600 miles when towing.
2013 F-350 6.7, Lariat, CC SB, 4x4, FX4, Tuxedo Black on Black, Transfer Flow 50 gallon, Method Racing 20" NV, 295/65/20 Toyo A/T II's
lwg is offline
post #7 of 10 Old 07-24-2013, 01:34 PM
Trigger01's Avatar
What does it cost to have the dealer reprogram it. I have been thinking about doing this to my truck.
2008 F-350 Lariat 4X4 CCSB
Trigger01 is offline
post #8 of 10 Old 07-24-2013, 01:59 PM
lwg
I think they charged me either 1/2 hour or a full hour to do it. They didn't even know that was possible until I told them about it. I also tried to get them to drop the TPMS values down as I drive an F-350 and they are rather high. They wouldn't do that though. I'll find a dealer eventually willing to take that "risk" for me...
lwg is offline
post #9 of 10 Old 07-24-2013, 06:03 PM
Trigger01's Avatar
Forgive me, but what's the tpms?
post #10 of 10 Old 07-24-2013, 06:19 PM
Tire pressure monitoring system
Take a stand today, join your local Fire Department or First Responder/Rescue team. We need all the help we can find!
Ken2012f350 is offline
