Camber/caster - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-09-2013, 05:09 PM Thread Starter
broncojason's Avatar
Camber/caster
I'm sure this topic has been beat to death, but I thought I'd ask anyways... Which camber/caster sleeves are being used on our trucks with the 2.5" leveling kits?
Thanks,
Jason
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #2 of 20 Old 07-09-2013, 06:13 PM
Icon has some with their leveling springs. You'll end up with 2 of Caster and 0 of Camber. This is a +2.3 sleeve.
You can get Specialty Products which makes a +2.6 sleeve, but after talking with Allen from Specialty Products he suggested I add a smidgen of Toe instead of the bigger sleeve.
There's a fair bit of opinion on the topic floating around the web with guys saying to run 4+ of caster, but I've yet to find someone who has expertise on the subject who agrees.
YMMV
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #3 of 20 Old 07-09-2013, 06:33 PM Thread Starter
I know exactly what u mean; after a quick search on this topic, it really blew my mind. Right now I'm running 1.5" readylift spacers, and never felt the first bit steering issues, but I think I'm gonna bump up the front to 2.5", since I just installed my F350 rear blocks this past weekend. I figured the 2.5" lift in front would be nearing the limit on the stocks specs, so I wanted to get the correct sleeves, that would get me back closer to where I needed to be.
post #4 of 20 Old 07-09-2013, 06:38 PM
Best advise I can offer is to call specialty products http://www.spcalignment.com/ and ask for Allen. Everything else is just folks on the internet with hearsay.
post #5 of 20 Old 07-10-2013, 10:35 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
These trucks will work better with additional castor...like every other solid axle truck Ford built had. Lack of castor is the main cause of wobble issues.
CT Performance, Inc. is offline
post #6 of 20 Old 07-14-2013, 04:32 PM Thread Starter
I ordered 2.5 degree caster (0) camber bushings, but I don't think they are gonna work. My factory bushings appear to have camber and caster built in. Have any of u guys ran across this?
post #7 of 20 Old 07-14-2013, 04:36 PM Thread Starter
Here are the numbers on the factory bushing:
post #8 of 20 Old 07-15-2013, 04:47 PM
My carli kit cam with inserts, when I had the truck aligned, they said the bushings weren't needed. However should I have them put in regardless?
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #9 of 20 Old 07-15-2013, 05:36 PM Thread Starter
From what I've read, the shops will say that our truck are within the Ford specs, but in actuality, after leveling, our trucks handle better with more positive caster.
post #10 of 20 Old 07-16-2013, 07:02 AM
Quoted: 3 Post(s)
The issue is Ford specs are 0-2.5*....insane...put the cam's in!
