what kind of tool - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-08-2013, 04:00 PM Thread Starter
what kind of tool
do Ford mechanics use to change fuses in a 2011 F350 6.7?
I just saw a mechanic change a fuse for the trailer wiring and that fuse box is not exactly handy. You need to have tiny hands to reach the back fuses. Do they use some sort of offset needle nose?
jepalmer is offline
post #2 of 4 Old 07-08-2013, 09:31 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
Fuse pullers.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 4 Old 07-08-2013, 10:42 PM
There is a white plastic fuse puller supplied on the inside of the fuse box cover.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #4 of 4 Old 07-08-2013, 11:23 PM
alaskan155's Avatar
Quoted: 60 Post(s)
if you cant find them, needle nose pliers do a good job....
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
