New truck pulls to right? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-07-2013, 06:40 PM Thread Starter
Ajc722's Avatar
12 I've just turned 3k miles. Pulls to the right real bad now. Haven't hit anything or taken it off road. Something from factory? Anyone else noticed this or am I fooling myself and just need to get an alignment?
Ajc722 is offline
post #2 of 14 Old 07-08-2013, 03:09 AM
WesGee's Avatar
Tire pressure is good? Don't rely on the sensors. If its not the tire pressure I'd take it to the dealer.
Sent from AutoGuide.com App
WesGee is offline
post #3 of 14 Old 07-08-2013, 04:23 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Take it to the stealership, it's not your issue so let them figure it out.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 14 Old 07-08-2013, 12:36 PM Thread Starter
Ajc722's Avatar
got an appt. at local dealership tomorrow morning. Pretty big dealership here in Tampa. (301 & adamo).
Ajc722 is offline
post #5 of 14 Old 07-08-2013, 12:42 PM
WesGee's Avatar
Brandon Ford?
WesGee is offline
post #6 of 14 Old 07-08-2013, 04:36 PM Thread Starter
Ajc722's Avatar
Yes, Brandon Ford. I actually purchased it from Gator
Ajc722 is offline
post #7 of 14 Old 07-08-2013, 05:26 PM
WesGee's Avatar
I got mine at Veterans Ford over off of Linebaugh but a good friend of mine is a sales manager at Brandon Ford.
WesGee is offline
post #8 of 14 Old 07-09-2013, 04:43 PM Thread Starter
Ajc722's Avatar
Took it to the dealership today. The tech put it on the rack and said everything was within specs. I said let's go for a ride and you will see. So I let him drive, and it started to pull. He tells me it's the crown of the road and the truck does that. I couldn't believe it. I must of had idiot on my head and didn't know it. So he tells me he can order a shim or something but dosent think it will change anything. Needless to say, I got my keys and left. Off to another dealership I guess.
Ajc722 is offline
post #9 of 14 Old 07-09-2013, 06:13 PM
Quoted: 4 Post(s)
Def. take it to another shop and never go back there. Let us know what it turns out to be.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #10 of 14 Old 07-09-2013, 07:03 PM
bubmiller's Avatar
Try changing tires. I had the same problem with a low mileage sprinter van. Pulled so bad I was the only one in the company that would drive it. Got an alignment, changed brakes, rotors, struts, rack&pinion, rotated tires. . . Nothing helped. After 10000 miles of miserable driving I had to change the worn out bfg's. Problem solved! Never suspected them cause they had less than 1000 miles when it started, and rotating didnt change it.
06 F250 CCLB
Bulletproof FICM
Sinister EGR Delete
Pypes Exhaust
ARP studs
SCT X3 w/Pro Racer
bubmiller is offline
