6.7 daily driver/weekend puller - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-03-2013, 04:59 AM Thread Starter
Dman115's Avatar
Heres some stuff from our local truck pull this weekend. All my info about the truck should be in the sig. Took 6th place out of 20 and i think i was the only truck in the open diesel class that drove there (and home thankfully).
Name:	truck pulling.jpg
Dman115 is offline
post #2 of 13 Old 07-03-2013, 05:14 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
Looked good. the second vid showed what I'm scared of with my truck, that front end hop. I plan to get the RCD 4-link kit to eliminate that. What gear did you get into?
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #3 of 13 Old 07-03-2013, 05:21 AM Thread Starter
Dman115's Avatar
I usually run 1st 4x4 high. But the track wasnt very good and i spun like 3500rpm.
Dman115 is offline
post #4 of 13 Old 07-03-2013, 05:28 AM
Quoted: 4 Post(s)
Have you tried low range and let it shift gears? That should get you up and moving quicker and allow you to use you're gears to get you're final drive closer.
Brett
post #5 of 13 Old 07-03-2013, 12:18 PM Thread Starter
Dman115's Avatar
Not sure how i feel about letting it shift while pulling. Im sure thats hard on the tranny and im always afraid it will do something i dont want it to.
Dman115 is offline
post #6 of 13 Old 07-03-2013, 02:41 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
ALWAYS pull in 4lo. And as far as shifting, im not sure on your trans, but I start in first gear and then shift to second and keep it there. Im sure the trans would be fine shifting on its own
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 13 Old 07-03-2013, 02:46 PM
Quoted: 4 Post(s)
while shifting does create heat, the stress on the tranny is cut way down by the added gear reduction the transfercase adds. not to mention how much strain do you think that TC is under when you take off with 40k+ lbs in tow in high range? shifting gears will net you a quicker acceleration while the sled load is low giving you more momentum to carry you furth down the track.
PS- sled pulling in general is hard on EVERYTHING, regardless of tranny gear, final drive ratio, or any other variable. everything is put to the max for 20+ seconds at a time. but dam its a hell of an adrenaline rush.
Brett
post #8 of 13 Old 07-03-2013, 02:46 PM Thread Starter
Dman115's Avatar
Haha thanks but ill stick with what works. Ive pulled in 4hi more than once. And if i did go 4lo i would shift to at least third, maybe 4th depending on track conditions. Ive taken several 1st doing things the way i have been and just thought i would share my experiences. I took 6th this time because it was an open diesel class and everyone that beat me had over 200hp more than me.
Dman115 is offline
post #9 of 13 Old 07-03-2013, 02:53 PM Thread Starter
Dman115's Avatar
Yes it is very hard on everything. We have 3 4x4 modified gas trucks and ive seen alot of carnage. But im just saying that it would be unnecessary stress. But i see your point of getting the sled moving faster. Times i wish i had my own sled to test all the theories i hear lol.
Dman115 is offline
post #10 of 13 Old 07-03-2013, 03:08 PM
Quoted: 4 Post(s)
i know what you mean about carnage. we have a 600" big block ford pulling truck and have seen our share of busted rear ends, burnt trannys, broken driveshafts, etc.
FYI- you are actually putting more unnecessary stress on it by doing it in high range. think of it as pulling a very large heavy trailer wide open from stop light to stop light, would it be easier to do this in high range and let the tranny hold the motor all in one gear and slip,or do it in low range and stay in 1st for a short time then hit second, 3rd, etc. you want that low gear to get you up and rolling and the motor revved up to get that tranny locked up and not making as much heat.
ultimately it is youre truck and youre tranny so it is youre decision on how you use it.
Brett
