Exhaust question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-07-2013, 10:50 AM Thread Starter
Dieselfreak12's Avatar
Exhaust question
Ok guys I have a 12 f-250 and don't want to delete but would like alittle more sound on the exhaust end. I have searched and everything I have found it about deleting the dpf I would just like to remove the muffler. Is that going to give me any more sound or just a waste of time and just wait till I delete everything. Thanks
Sent from AutoGuide.com App
Dieselfreak12 is offline
post #2 of 8 Old 06-10-2013, 07:16 PM
cumminchevy's Avatar
I removed the factory tail pipe (dpf back) an replaced with stainless 5" Mbrp. No difference in sound but look much better than factory
2012 F350 PSD Lariat FX4 CC single wheel. 5" stainless MBRP dpf back. Carli pintop w/ full deavers, long travel air bags, high mount stabilizer, Walker Evans street wheels 17x8.5s w/5.5 bs and 37x13.5 Toyo Open Country MTs
cumminchevy is offline
post #3 of 8 Old 06-11-2013, 05:59 AM Thread Starter
Ok thanks for replying
post #4 of 8 Old 06-11-2013, 06:35 AM
You aren't going to get more sound w/o deleting. The DPF back stuff is cosmetic only.
I went thru that stage, then deleted. Deleted is much better
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #5 of 8 Old 06-11-2013, 04:39 PM
Hellobatman's Avatar
Got a pic of this by any chance?
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
post #6 of 8 Old 06-12-2013, 08:01 AM
Before
After
That's the 5" MBRP w/ 6" tip. I found it to be a very tight fit around the rear shock, rubbed a little.
Then I went to the aFe 5" and there's plenty of room now - of course that's not a filter back one .
post #7 of 8 Old 06-12-2013, 08:03 AM
Originally Posted by TrickTruck View Post
Before
After
Looks good! Thanks for the follow up.
post #8 of 8 Old 06-12-2013, 06:14 PM
Hey Trick what muffler did you use and does it get rid of 50% of the squeal when the wastegate opens?
I've got the same as you, with a tight fit around the rubber shock boot as well. I was straight pipe all the way, then put on the Flowmaster Huspower and was NOT impressed. It took away maybe 20% of the "squawl" (???) sound and I still dont like it. I like the sound that comes from the older 6.4 but I know it's totally different.
I'm tempted to divert the 5" into twin 3" Flowmasters made for the gas engines, then actually run twin 3" tubes out each rear corner. Expensive adventure if it winds up sounding like crap again.
FORDTUF1 is offline
