Add Rapid Heat and Dual Alts? How Difficult? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-31-2013, 12:27 PM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
As the title says, anyone have any info on this? Can you go to the dealer, if the price is right which it wont be, and have them install those or is it pretty easy to put in?
new belt and alt for the dual alts
rapid heater, tie in to the fuse box
What am I missing?
TX_TRU_STUD is offline
post #2 of 15 Old 05-31-2013, 12:42 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I watched a youtube video where a guy put dual alts in his 7.3, pretty straight forward. remove belt, install alt, wire up, reinstall new belt. its probably more complex than that but i cant recall. id imagine its about the same for 6.7s
as for the heater, are you talking about the supplemental cab heater? if so i recall i read a thread where someone said it wasnt possible it had to be installed at the factory.
I know vague as hell sorry
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 15 Old 05-31-2013, 12:47 PM
ZMANN's Avatar
Quoted: 1454 Post(s)
ALT Options
7.3'swere simple the 6.7 is PCM operated
I would find a good replacement for the single like from DC Power and have one great alts instead of 2 so so alts
supplemental heat = no idea but you sure made it sound easy
We Miss you Ronnie
ZMANN is offline
post #4 of 15 Old 05-31-2013, 12:49 PM
Chapter Director
Quoted: 5 Post(s)
Originally Posted by ZMANN View Post
ALT Options
Yea i kinda figured, but i know you have to do at least those 4 things
Thats kinda what i will do with my alt when it dies, its a way better alternative
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 15 Old 06-01-2013, 08:30 PM
2012SD's Avatar
I was wondering about the dual alt myself. I wanted that option, but mine has the HD one. I would still like to add the second alt for the light package I plan to add, but wonder what exactily it will take. (Second alt, mounting brackets, wiring, and PCM update??) Might have to ask the dealer next time I'm in for service.
2012SD is offline
post #6 of 15 Old 06-01-2013, 08:37 PM
ZMANN's Avatar
you would still be better off with a better single ALT with a greater output at Idle and cooler running
also you would be money ahead IMHO and have your good take off as a spare vs tryng to figure out which one of your two alts crapped out and where to find a replacement on a weekend
We Miss you Ronnie
ZMANN is offline
post #7 of 15 Old 06-02-2013, 01:28 PM
I too was researching on installing dual alternators. You MUST change the water pump as well.
Here is an install diagram w/ parts needed..
https://www.fleet.ford.com/truckbbas...ml/Q-160R1.pdf
I ended up scratching the idea of adding a dual alternator, but I plan on upgrading to a DC power or Mechman alternator instead which will bump up the idle amperage and overall amperage pretty much to the same amount as a dual alternator setup.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #8 of 15 Old 06-02-2013, 02:18 PM Thread Starter
Quoted: 52 Post(s)
Damn that sux. I guess ill stick with the one I have and upgrade it if need be.
post #9 of 15 Old 06-05-2013, 02:08 PM
doczenith1's Avatar
Quoted: 7 Post(s)
There were some threads about adding the supplemental heater back in 2011. If my memory serves me right the cost was around $2000 installed. It really puzzles me when dealers in northern climates order trucks without the option to put on their lots. For $250 (I think) it's a no brainer to me.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #10 of 15 Old 06-05-2013, 07:51 PM
Quoted: 14 Post(s)
You only need the HD alt for the Rapid Heat. You don't need the dual Alts for that option. So upgrading the Alternator would be fairly simple
The real challenge is tearing the whole dash out to install the rapid heat element in the heater box.
It is automatic, No switch to turn it on/off.. So some programming has to go into the PCM to let it know you have the element
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
