which level kit to go with? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-27-2013, 05:21 AM Thread Starter
ToyoTundra11's Avatar
looking to level the truck or keep stock height. but would like to run 35's. any issues with fitment on stock wheels or will i need to go with aftermarket wheel and what off set / back space.. also, what is fuel mileage after changing tires and / or adding spacer kit. i currently get 16 / 21.
ToyoTundra11 is offline
post #2 of 5 Old 05-27-2013, 05:41 AM
BlueOx12's Avatar
You can run 35x12.50x20 on stock rims at stick height. It will rub slightly on the radius arm but you won't feel it being that it's smooth stamped steel. Here's a pic of mine before the lift was installed.
Sent from AutoGuide.com App
05 6.0 Extcab 4x4
Studded, Deleted, Tuned, and Sprayed.
BlueOx12 is offline
post #3 of 5 Old 05-27-2013, 12:20 PM
I have 285/75/18 ( toyo calls them 35x11.5x18's) on my stock 8" wide wheels. No rubbings of any kind and no leveling kit
GroverDill is offline
post #4 of 5 Old 05-27-2013, 12:33 PM
BIG Laing's Avatar
35x12.5 works on stock wheels. 35x11.5 or 34.5x12 is perfect IMO.
MPG will drop about 1 when you level it, and put a slightly wider heavier tire. If you are worried about mpg loss, leave it stock!
Spacer kit should not even cross your mind.
If you do level it, icon or Carli is the only way to go.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 5 Old 05-27-2013, 05:17 PM
raftdaddy's Avatar
I have 325/60/20 (35.5)on stock wheels and they do rub the radius arm at full lock.you don't even notice it just see fresh polished metal on the arm! the only thing you have to look out for is a wire that runs on the radius arm on the passanger side,the bigger wheel will grab it and pull on it. I just flipped the plastic connector to the inside of the arm. and I really like the readylift sst kit,very complete. and don't forgrt to upgrade your steering stabilizer as well,makes a world of difference.
no level yet, my readylift stuff is here just no time to get to it.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
