Which Gear Ratio would be better for 35s? 3.31 or 3.55 - Ford Powerstroke Diesel Forum
post #1 of 26 Old 05-18-2013, 07:44 AM Thread Starter
colecoop56's Avatar
Hey guys I am about to order my truck from the dealer and I am trying to figure out which gear ratio to go with. Will one be better than the other if I want to run 35s? I want the gear ratio that will get me the best mpg when I step up to 35s and the ratio that I will be happy with in the future. I know my duramax im trading in has 3.73 and they seem perfect for my 35s. Can someone please tell me which ratio would be better for me and the benefits of each ratio. I just don't want to mess up and get the wrong one.
Thanks,
Cole
colecoop56 is offline
post #2 of 26 Old 05-18-2013, 08:14 AM
WoodBoy's Avatar
3.55. You can only get 3.31 with the stock 18s anyways. If you was going to leave it stock size tires and wheels and do alot of highway I would say 3.31 but the 3.55s seem to fit everyone's needs
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 26 Old 05-18-2013, 09:44 AM
Baddestt's Avatar
Quoted: 8 Post(s)
Pretty simple answer: 3.55s. You'll burn more fuel with the tall 3.31 and 35s.
Enjoy the new truck when it comes in
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #4 of 26 Old 05-18-2013, 12:47 PM Thread Starter
colecoop56's Avatar
Thanks guys. Thats what I was thinking
post #5 of 26 Old 05-18-2013, 05:49 PM
2013F250Tank's Avatar
i had 3.55 and hit 6th gear at 40mph. Have 3.31 now with 33s and dont hit 6th till 50mph. Gearing is low enough in the new trans i'd go with 3.31.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #6 of 26 Old 05-18-2013, 05:54 PM Thread Starter
colecoop56's Avatar
Ya but if I wanted to go 35s I'm not sure. What mpg are you getting with the 33s and 3.31 gears highway if you dont mind me asking
post #7 of 26 Old 05-19-2013, 10:26 AM
60 mph driving like a grandpa 21 mpg. Around florida so flat helps too.
2012 F250 TOTALED.
post #8 of 26 Old 05-19-2013, 10:47 AM
6.0f250firstcar's Avatar
3.31 gears with the bigger tires are going to be really tall. IMHO the 3.55 gears are just right for these trucks.
Ryan
6.0f250firstcar is offline
post #9 of 26 Old 05-19-2013, 11:27 AM
I have 35"s (285/75/18 Toyo M/T) with 3.31's with 800ftlbs at 1600 rpm I can honesty say I can hardly even tell the difference over the stock 33.2" tires (Connti 275/70/18 AT's).
GroverDill is offline
post #10 of 26 Old 05-19-2013, 07:32 PM
raftdaddy's Avatar
just order the stock 20's they have a 34.7 tire,then your done!!
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
