best ford service dept. in or around Lexington, KY??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-18-2013, 04:01 AM Thread Starter
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Moving to Lexington, KY. at the end of this month and was wondering which Ford service dept. has the best reputation in Lexington??? All input is appreciated.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #2 of 6 Old 05-18-2013, 11:19 AM Thread Starter
Quoted: 4 Post(s)
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #3 of 6 Old 05-18-2013, 07:35 PM
bocephus1983's Avatar
I believe Paul Miller Ford is the only dealership in Lexington. I've never had any work done there but I know they have a large fleet sales dept. So I would assume they have a large service dept. the only other Ford dealer I know of in the area near there is Kain Ford in Versailles. Just leave out of Lexington on Versailles Rd. and you'll run right by it. Hope that helps. If you don't mind the drive there's also a dealership in Frankfort. I have heard people say good things about there service dept.
bocephus1983 is offline
post #4 of 6 Old 05-19-2013, 04:33 AM Thread Starter
Quoted: 4 Post(s)
Thanks for the input. where do you take your truck, or do you DIY???
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #5 of 6 Old 05-21-2013, 05:21 PM
bf250's Avatar
There is also Wildcat Ford just a couple minutes south of lexington. Its on the way to Nicholasville. I have used them and Paul Miller. Dont have complaints with either. I use Wildcat Ford because it is closer to where I live.
bf250 is offline
post #6 of 6 Old 05-21-2013, 08:44 PM Thread Starter
Quoted: 4 Post(s)
Thanks guys for the input. I will be living closer to Wildcat Ford so will probably go there. I can always count on great input here.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
