Lack of throttle response and hard shifting??? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-14-2013, 05:30 AM Thread Starter
Hey guys, on my 2012 lariet i am having trouble with it shifting hard or iratic from 1-2 and 2-3. I also have some lag when pushing on the gas pedal, i usally have to push it a 1/4 inch before anything happens then after that its super sensitive , so much that its hard to drive without spinning, Its a reall pain in the *** when in traffic of even a parking lot for that matter, I read that there were some updates to correct this but could not find any tsb info. If anyone know and could point me in the right direction that would be great. thanks
machinest660 is offline
post #2 of 17 Old 05-14-2013, 07:42 PM
dslbrnr's Avatar
I have a similar issue.
SOLD 2012 F350 CC, SB, Lariat 4X4, 3.31's, E-Locker, Line-X'd
dslbrnr is offline
post #3 of 17 Old 05-14-2013, 10:20 PM
Northernford's Avatar
Exact dame thin happens to me. Talked to another guy on here and he said it was his transmission pump. Took it to the dealer and they replaced it, problem gone. I have no idea how the throttle response has to do with that but if it fixes it, mine is going in the shop next week.
2011 F-350 FX4
Northernford is offline
post #4 of 17 Old 05-15-2013, 08:05 PM Thread Starter
If the fix your please let me know how it worked out and if there was a service recall on it, i talked to a few guys that have the touchy throttle issue and the said there problems went away with a tuner but i dont wanna go that route till warrenty is up
post #5 of 17 Old 05-15-2013, 08:16 PM
Yessir will do. Truck will hopefully be going in early next week. Eventually I would like a tuner but stock maybe the best way to go in terms of reliability.
2011 F-350 FX4
post #6 of 17 Old 05-15-2013, 08:36 PM
How much to replace the transmission pump?
Madukrainian is offline
post #7 of 17 Old 05-15-2013, 08:37 PM
I have no idea. Thankfully I am still under warranty so I don't have to worry about it.
2011 F-350 FX4
post #8 of 17 Old 05-15-2013, 08:39 PM
Crap I'm not I just bought a 2002 and its sensitive as well on the throttle only in the first gear. As soon as I hit 1300 rpm it's normal though.
post #9 of 17 Old 05-15-2013, 08:43 PM
That may be another problem since its a different transmission, different pump and everything else. It may be the problem but I don't know anything about the older trannys. Depending on where you bought it you may have a used car warranty.
2011 F-350 FX4
post #10 of 17 Old 05-16-2013, 05:50 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
If it's still under warranty, take it in!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
