DDM HID's...passenger side intermittent - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-13-2013, 11:36 AM Thread Starter
Hellobatman's Avatar
Anyone have a problem with their HID's not firing on the passenger side?
I've got the DDM hi/low H13 kit installed correctly, and connected to the pass side H13 connector, yet my drivers side is the only side constantly firing when they are turned on.
The pass side has come on intermittently, but as of lately not at all. Any advice would be appreciated.
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
post #2 of 17 Old 05-14-2013, 10:54 PM
BgCountry's Avatar
I just installed some Spyders with RFS HID's and had the same problem. RFS had to make me a Diode that I plugged into the open end of the factory harness. Fixed the problem. I would re-check all wires and see if something has come loose. I had to splice some wiring, but I shrink wrapped everything before final install. Then had to take loose several time to adjust the beams.
Oh, I also broke the plastic little arm that goes into the hole along the inner fender, but the Headlight has 4 screws that hold it in place anyways, and its a TIGHT fit, so I dont think I will have any problems.
Then I stripped one of the screw holes and had to put some gorilla glue in order to get tight.
Talk about a PAIN IN THE A** to install. I think I ran into every problem that you could run into. LOL
2012 F350 Lariat PS CC FX4 Tuxedo Black, Tinted, 20's, Recon Side Lens, 3rd Brake Light, De-Stickered, Epic Door Seal Mod, Reflex Liner, Spyder Headlights W/RFS 5K HID's, B&W Turn Over Ball W/Andersen Ultimate Fifth Wheel Connection.
2011 Keystone Laredo 310 RE
BgCountry is offline
post #3 of 17 Old 05-15-2013, 05:12 AM Thread Starter
Sounds like you hit every brick on the road! Lol sorry to hear that man.
So my kit runs off of one side...the harness plugs into the drivers side and the pass side has nothing pluggged into it. Is this how yours works too?
How's the diode work? Like an in line deal?
post #4 of 17 Old 05-15-2013, 05:31 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i had a bad wire on my kit from them on the passenger side. the wire was not fully inserted into the plug so i forced it into the piece of plastic and filled with super glue.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #5 of 17 Old 05-15-2013, 06:12 PM
BgCountry's Avatar
My kit is the exact same. I had to plug the Diode into the open end of the harness to make sure the Lo beams come on when the Hi beams are on. I originally installed the kit without the Diode and it would work sometime and then would just shut off.
There is another member on here who has a DDM kit and his installed perfectly. I would check all the wires like Tractor said.
post #6 of 17 Old 05-15-2013, 06:26 PM Thread Starter
I had to extend the driver's side harness line bc it was too short. I did it very meticulously and shrink wrapped everywhere so ive def ruled out that side. It fires every time.
My damn passenger side is just the issue. Ive swapped brand new ballasts and nothing. I'm gonna swap bulbs this weekend and see if its a bulb problem. If the bulb works then the only thing I'm left with is thinking its the hi/low harness...
Any advice...?
post #7 of 17 Old 05-15-2013, 07:22 PM
Quoted: 2 Post(s)
Or it could be the simple fact that ddm is garbage.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #8 of 17 Old 05-15-2013, 07:30 PM Thread Starter
Could be...sad to say. I've been using their kits back from 06/07 and they were always flawless. Have had nothing but troubles in the past 2 years.
What's a better, more reputable kit?
post #9 of 17 Old 05-15-2013, 07:31 PM
Quoted: 2 Post(s)
Trs is about as good as it gets.
jcain is offline
post #10 of 17 Old 05-15-2013, 07:48 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 21 Post(s)
Feedback Score: 12 reviews
X2. Theretrofitsource.com
I've said it again and I'll say it again.. Lol. If u wanna do hids, then do them right. You need to do or pay somebody to do an hid projector retrofit, then you'll have a true hid lighting system, using the hid bulbs as they were designed to be used- with an hid projector. Hids weren't designed to be installed in halogen reflector housings. Read the link in my sig for a parts list from trs and a how to guide to do a retrofit on your own. It can be done in a weekend.
Sent from AutoGuide.com App
2017 f250 platinum
Deleted at 8k miles.. trying to be patient waiting for custom tunes...
mts678 is offline
