2013 break dust - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-05-2013, 08:42 PM Thread Starter
arcticatman's Avatar
2013 break dust
Hey guys we just picked up a 2013 super cab loaded, great rig i love all the luxury features over my 6.4 but one big complaint is the break dust after only 1k miles the front wheels are black and the rears are already going that way! is there a solution for this or should i just put better pads in it?
Thanks for the help Cody[IMG]
[/IMG]
1997 350 7.3 dump truck/Work Truck
2008 350 Reg Cab
H an S 300 tune
Flo pro egr delete with elbow
Flo pro 5 inch turbo back
s an b intake
Cat ELC
Ready Lift 3.5 sst kit
20inch Platinum wheels
Much more to come!
arcticatman is offline
post #2 of 11 Old 05-06-2013, 06:58 AM
HUH??? I have had a 2011 and a 2012. Both trucks were very clean brake systems once broken in. Maybe Ford has changed the pad material for the 2013 models but I kinda think you should wait a couple thousand miles and see after they get seated.
I remember at first I thought the pads were very dusty but they cleared right up very quickly. I can say that it takes some miles to get the brakes broken in and seated. The first 500 miles are scary if you have to stop fast. By the time you get 2000 miles on them they feel a lot better and you start depending on them more. After 15 - 20 thousand miles these trucks have awesome brakes. I believe since they are slow to seat, they may last a long time too??
Anyway, get some miles on your brakes and I think you will be pleased, , , , and clean your wheels!!!
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #3 of 11 Old 05-06-2013, 07:14 AM
2013F250Tank's Avatar
I also have a 2013 F250 and i put American force polished wheels on even after a 60 mile highway trip they are coated. Im buying ceramic pads and looking into the "brake dust guards" that go on the back side of the wheels to block dust.
2013F250Tank is offline
post #4 of 11 Old 05-06-2013, 05:54 PM
ucpa111's Avatar
Quoted: 3 Post(s)
I have a 2012...never had a brake dust issue. What you are explaining did not happen on my truck. Now, maybe I just clean it frequently LOL! Seriously, I think something must have changed for you to see that much.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #5 of 11 Old 05-06-2013, 09:56 PM Thread Starter
Ya really aggravating guess ill swap pads when i do the first oil change? I dont know what else to do. Thanks for your input guys
2008 350 Reg Cab
H an S 300 tune
s an b intake
Cat ELC
Much more to come!
post #6 of 11 Old 05-07-2013, 08:12 AM
Tuxedoblack's Avatar
I wouldnt have know washed mine more than likely twice a week back then, no dust now at 6700 but keep close eye on the birds
Tuxedoblack is offline
post #7 of 11 Old 08-13-2013, 05:44 PM
I purchased a 2013 in May. It now has 2800 miles from the drive out of Mexico. It is now in the shop for a quick check on the brake dust issue. Mine has dusted the front wheels quite noticeably and wanted to make sure there is not a problem. The rears have not been and issue as of yet. So far the dealer is saying everything is checking out okay, but they seem to be heating up more than normal. We'll see as time goes on I guess.
2013 F-250 6.7 CC 4X4 FX4 3.55's Built & Retrofitted for Mexico at the Kentucky Truck Plant (No DEF, No DPF, Factory delete exhaust, and no Regens, Runs on high and low sulfer diesel, WOW!!)
thirdculturekid is offline
post #8 of 11 Old 08-18-2013, 06:31 AM
Didn't they change brakes in 2013? Maybe pads are different?
Sent from AutoGuide.com App
13 f-350 ccsb platinum
05spudman is offline
post #9 of 11 Old 08-18-2013, 06:52 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
The brake rotors are larger and may be the reason for more dust.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 11 Old 08-18-2013, 07:27 AM
Quoted: 4 Post(s)
I noticed excessive dust from mine too. Seems to be getting better. I'm at 3000 miles now.
Deerhunter4 is offline
