SRW Crew Cab Long Bed 4X4 1 ton braking - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-02-2013, 09:09 AM Thread Starter
Quoted: 3 Post(s)
I have the above truck and whenever I jam on the brakes hard the truck pulls hard to the left and one time I hit the brakes hard on the highway and it felt like the back end was going to swing around. It required a lot of correction with the steering wheel on my part. All unloaded. The front to back issue feels like brake bias but the hard pull to the right has me concerned. Anyone else have this issue or thoughts? I was going to pull the front wheels off and see if there is anything inhibiting the calipers. Other than a full bleed of the system I am at a loss.
2016 Ford F-350 King Ranch 4x4 Super Crew 8 Foot bed. 2014 F-150 Super Crew 6.5 Foot bed 4x4 Platinum.
MisterScott is offline
post #2 of 2 Old 05-02-2013, 09:52 AM
Check caliper/rotor temps. After a couple stops, by hand should be close enough. Good chance you're going to find the front right isn't very warm... That or the left front tire is way low on air.
tailchaser is offline
