NO HELP FROM FORD - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-02-2013, 07:23 AM Thread Starter
NO HELP FROM FORD
We have been told by FORD MOTOR CO. that there is nothing that can be done for our 2011 F-350 6.7 casastrophic engine failure (bad valves) truck has 150K miles. Have been told by Ford mechanic that he has seen 7 others with the same issues and Ford Motor has agreed to replace a hand full. What is wrong with that picture. Any one else have the similar issues? We are seeking an attorney due to this.
Advanced Equine Dentistry is offline
post #2 of 6 Old 05-02-2013, 07:44 AM
MDarrough's Avatar
Quoted: 2 Post(s)
Looks like there's been a few cases of this.
Good luck!!
6.7L 103K! Cracked Valves and out of Warranty! What's Ford Gonna Do?? - Ford Truck Enthusiasts Forums
2011 6.7L BAD VALVES/PISTON - Ford Truck Enthusiasts Forums
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #3 of 6 Old 05-02-2013, 09:33 AM
brendan.9's Avatar
you have a 150kmiles what are they going to do? if you had 50k way different story but 150 there going to tell you to pound sand i don't blame em, ya it shouldn't have happened but theres always a few that this happens to in every motor made.
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #4 of 6 Old 05-02-2013, 09:45 AM
2013Platinum's Avatar
I have no idea why they would help you, yes it sucks, but it really is not Fords problem anymore. Unless you get thousands of people that have issues and all make a complaint, they will not do anything.
1 person having an issue after using a heavy duty for 150K, its not a surprise to need maintnance. with 50k, i could see, 150k, no way
2013 F250 Platinum!
5 Inch MBRP Straight Pipe
S&B Intake
EGR Delete
Mini Maxx (DPF OFF)
2013Platinum is offline
post #5 of 6 Old 05-02-2013, 11:17 AM Thread Starter
A mechanic at a Ford dealership in Az posts interesting you-tube clips.
The 6.7 liter Scorpion engine made in Mexico by Ford has a failure pattern
in the non-waste gated chassis---F 450 and 550.
Multiple exhaust valve fractures in vehicles with as little as 20,000 miles.
apparently Ford is redesigning the head
here are 3 short clips
jh
(Found this post) Pretty interesting...
post #6 of 6 Old 05-02-2013, 11:18 AM Thread Starter
Some are reporting less than 20K and still not doing anything about it..
