water removing fuel additive - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-28-2013, 03:41 PM Thread Starter
6.7strokin's Avatar
I recently drained about 2 drops of what appeared to be water from my DFCM, it had been about a month and a half and about 10 tanks of fuel since I had drained it. I have since drained my DFCM about every half tank of fuel. I get the slightest trace of water (about a dozen dots about the size of mechanical pencil lead) in the bottom of the jar every time I have drained the DFCM since the first incident. I have never gotten a water in fuel light. Due to the very small amounts of water I am seeing I don't think this is a situation that points to heavily contaminated fuel that requires a tank drop and clean. I would like to hear some recommendations as to which fuel additive you guys would recommend to dry up what little bit of water may be left in my fuel tank. I am leaning towards the diesel 911 winter fuel treatment. From what I have found it seems to be safe to use on the 6.7. Have any of you ever used it or do you have any other recommendations?
6.7strokin is offline
post #2 of 7 Old 04-30-2013, 02:08 AM
Ajc722's Avatar
I have used sea foam in the past.
Ajc722 is offline
post #3 of 7 Old 04-30-2013, 02:52 AM
I use Lucas Fuel Treatment. I would be careful with all the sensors on the engine you may have a problem. Even some of the containers will have warnings on use their product concerning the newer engines. It would be great to get a straight answer.
HCFR34 is offline
post #4 of 7 Old 04-30-2013, 04:01 AM
I've used Power Service Diesel Kleen and Opti Lube XPD in the past and like both. Diesel Kleen is readily available in most retail stores whereas Opti Lube has to be ordered online.
jddotson is offline
post #5 of 7 Old 04-30-2013, 11:42 AM
doczenith1's Avatar
Quoted: 8 Post(s)
Fuel additives will not remove water from fuel. There are two types of additives. Demulsifiers and emulsifiers. A demulsifier will cause the water and fuel to separate and your DFCM will catch the water and keep it from moving to the engine. That's it's job. You DO NOT was to use a fuel additive that contains an emulsifier. An emulsifier will cause the fuel and water to mix and if that happens your DFCM will be unable to catch the water before it enters your engine and then bad things happen to your fuel system.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #6 of 7 Old 04-30-2013, 02:36 PM
Seems like your water seperatly is doing its job
2011 F260 6.7 CC 4x4 LB
gsxr1300 is offline
post #7 of 7 Old 04-30-2013, 03:56 PM Thread Starter
6.7strokin's Avatar
I do agree that the water seperator is doing its job. The truck never sits for more than 24 hours without moving but maybe what I am seeing is some condensation. I picked up a bottle of Power Service Diesel Fuel Supplement. Hopefully this will keep the water separated and the DFCM will continue to catch it. Its just makes me a little paranoid to see water, although it be small droplets, coming out of the water separator after hearing all the horror stories about fuel system replacement due to water contamination on the 6.7's
