Different size spare - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-26-2013, 09:42 AM Thread Starter
bf250's Avatar
I was under my truck doing a couple things and happened to notice the size of my spare tire. I have the factory 20s. 275/65/20. My spare tire is 275/70/18. Am I correct that i can not use this tire as a spare if something happened? Dont all tire sizes have to be the same diameter on a 4 wheel drive vehicle? I bought the truck new from dealer. Did they just add the 20s and forget about the spare? Can I take it back and have it replaced if needed? I bought it new in 2011.
bf250 is offline
post #2 of 6 Old 04-26-2013, 09:55 AM
Quoted: 2 Post(s)
No I think you are fine. Someone else will confirm though.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #3 of 6 Old 04-26-2013, 11:20 AM
I've read here that you just make sure you put the spare up front to keep the rear 2 wheels/tires matched. So if a back tire goes out you need to move one of your front wheels to the back and put the spare up front.
I'm sure someone who understands this will explain reasoning, but that's the process from what I understand.
FordOD is offline
post #4 of 6 Old 04-26-2013, 12:07 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
This is correct if you have a limited slip rear end because running 2 different size tires will wear out the clutches in the limited slip real fast.
If you have an open diff. then you can run different size tires without hurting it.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 6 Old 04-26-2013, 02:56 PM
BIG Laing's Avatar
Those tires are 1" different in diameter. You would have to put the spare up front like everyone has already stated.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 6 Old 04-28-2013, 03:16 AM Thread Starter
bf250's Avatar
Thanks for the input
bf250 is offline
