Airbag Install With Stock Under Bed Hitch - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-20-2013, 04:21 PM Thread Starter
To Many Projects
Twinjracing's Avatar
Quoted: 14 Post(s)
Well I'm going to try do another write on my '2012's airbag install.
First off read the instructions and use them, I do; but here is the highlights with pic's
I first read and read and read just to make sure you don't miss any thing and have a good idea of what your going to do.
then I lay every thing out
You start off by removing the bump stops. Then next you put on the drivers side upper mount in ( which is a $#%&*&!@#*%&**%$!&*& ) I took the idea from another person that did one and got a shorter bolt and added a second washer on the inside. Still had to grind the nut a little to fit between the frame and hitch side plate.
The pass side is a cake walk
Then you put the top and bottom plates on the airbags placing the carriage bolts where they need to go.
Then you place the bag in place making sure the bolt goes through the frame where the bump stop used to be. you also line it up with the upper bracket already installed.
Also make sure it's sitting on the block arm
A few of the pass Side
Then you put the L brackets on that hold the spring bracket bolts
Then you put the back bracket on
Then you put the carriage bolt trough the bottom plate and put the axle bracket on
Last you run the air lines how ever you want I run mine through the frame and put the valves in the bumper.
All done... also notice the heat shield on the pass side .
Thanks For reading TWINJRACING
17 F250 XLT CC LB SRW 4X4, Truxedo Lo Pro Cover, Spray In Bedliner, Airlift Bags, And Cobra 29LX
E99 F250 Ext LB 4X4 Terminator HPOP, Rosewood Stage 160/80, T4 Billet S366 66/74/1.10, NLTD Tunes, Custom Traction Bars, Custom Winch Bumper
71 Cutlass Supreme Dragcar, 66 GTO, And 72 Vista Cruiser
JJ
Twinjracing is offline
post #2 of 6 Old 04-23-2013, 02:53 PM
JuniorDiesel's Avatar
Twinracer, thanks for posting this! Looks like I ordered the same air lift bags as what you installed. Where did you go to get the shorter bolts for the upper brackets? Something I can get at Lowe's?
I also ordered the SmartAir compressor from Air Lift and will be doing the optional kneeling switch.
Sent from AutoGuide.com App
2007.5 Chevrolet Silverado LMM
MBRP Exhaust, Edge EVO CTS, Billstien 5100's, 18" XD Monsters, HID Lights (SOLD)
2012 Ford F-350 DRW
JuniorDiesel is offline
post #3 of 6 Old 04-23-2013, 03:44 PM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Yeah lowes should have it also get more washers 1/2 X1 1/4 long two of them
JJ
post #4 of 6 Old 04-28-2013, 11:25 AM
Twin, is that shorter bolt for the drivers side or passengers side bracket?
2012 Ford F-350 DRW
post #5 of 6 Old 04-28-2013, 11:26 AM
Or both?
2012 Ford F-350 DRW
post #6 of 6 Old 04-28-2013, 11:58 AM Thread Starter
To Many Projects
Quoted: 14 Post(s)
I did both
JJ
