F250/350 pin weight question - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-09-2013, 04:14 AM Thread Starter
I had a salesman suggest that the payload (pin weight capacity in my case) for a F250 with the camper package would be essentially the same as a F350, engine/4x4/crew cab being the same in both cases.
I can't find anything in the brochure that I downloaded that can confirm this.
What would be the pin weight max for each?
Thanks for the help.
jepalmer is offline
post #2 of 16 Old 04-09-2013, 04:35 AM
That's incorrect....the 350 will be able to LEGALLY carry around 1-1300 lbs more weight. If you have a question opt for the 350.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #3 of 16 Old 04-09-2013, 06:01 AM
dagnabit9's Avatar
All you need to do is subtract curb weight from GVWR and it'll tell you what your pin weight will be, i.e., if you have a curb weight (vehicle + fluids) of 7850 lbs and a GVWR of 10,000 lbs your pin weight would be 2150 lbs. However, any additional payload (passengers, cargo, etc.) will take away from that weight. I agree with Lrdchaos - opt for the F350.
USAF Retired (2P071)
2011 F250 KR FX4 4x4 CC SB
2006 F250 XLT FX4 4x4 CC SB, EGR Cooler Delete, AutoMeter Gauges, Scangauge II, SCT x3 Custom Tunes - SOLD!
2009 Keystone Raptor 33' Toy Hauler Fifth Wheel
2006 H-D ElectraGlide Ultra Classic
dagnabit9 is offline
post #4 of 16 Old 04-09-2013, 10:29 AM Thread Starter
thanks for the help. I keep looking for ways to make a F250 work and I keep coming back to an F350.
jepalmer is offline
post #5 of 16 Old 04-09-2013, 01:55 PM
I have been told by a Ford Dealer that the only difference between the 250 and 350 is one extra leaf spring, and the badging. Can anyone confirm this? If so, I will be adding a leaf spring to my 250.
Fordcrazy is offline
post #6 of 16 Old 04-09-2013, 01:57 PM
66Bronco's Avatar
All else being equal, the difference in price (online at least) is less than a grand from the 250 to the 350. Go one ton.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #7 of 16 Old 04-09-2013, 05:13 PM
There is that one extra leaf that contacts the bumpers on the frame, and the blocks between the axle and springs are 2 inches taller on the 350. The older (11's and maybe early 12's) trucks used hydroboost brakes on the 350, but I think they both use the same braking system now.
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #8 of 16 Old 04-09-2013, 06:36 PM
Quoted: 18 Post(s)
The F350 has 2 more splines on the axle shafts ( 37 vs 35) and the axle shaft itself is slight larger in diameter. As mention you get the extra leaf spring and in 2011 the Hydroboost Brakes. (the duallys still get the Hydroboost, but the SRW all get the Vacuum boost since 2012).
The F250 rear axle is rated at 6200 lbs
The F350 rear axle is rated at 7281 lbs
F250 F350
Axle Shaft Spline Minor Dia 1.36" 1.50"
Axle Shaft Spline Major Dia 1.50" 1.57"
No of Splines ( Hub end) 35 37
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #9 of 16 Old 04-09-2013, 08:16 PM
350ninty7's Avatar
I don't know about the 2013 models, but the Ford technical specifications listed for my 2012 F350 SRW with camper pkge @ 11,500 GVRW shows a listing of Max Payload Weight Ratings (lbs) of 3,790 lbs this is for a 4x4 Crew Cab 172" wheelbase. The rating for a F250 4x4 SRW Crew cab 10,000 GVWR with 172" wheel base is 3170 lbs. If you are comparing F250 to 350 for towing a 5th wheel as per the Ford specifications there is only a 500 lb higher Max Loaded 5TH WHEEL Trailer weight difference between the two models. For me and others IM sure the 350 is the best option, if you tow, or load a heavy camper go with the 350. This information I listed is from the 2012 Super Duty Ford truck brochure that your salesman should be able to provide for the 2013 models.
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
post #10 of 16 Old 04-09-2013, 08:26 PM
Quoted: 2 Post(s)
F250 F350
Go order some gears for a 2012 f250, you'll be surprised..
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
