Fuel Water Seperator Question - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-03-2013, 05:25 PM Thread Starter
79_bronco's Avatar
I just rolled over 1000 miles this week and it was my first time emptying the fuel water separator, but nothing seemed to come of the down spout.
I opened it to the 0 ring and kept going with only a few dribbles coming out (and quite a bit coming out of the actual yellow knob). Is this normal, and do i possibly not have any water in my fuel? It seemed like something should always come out, but I wasn't sure.
I would also like to note that I did add some of the silver diesel power service in this tank of fuel (about 1/2 gone now) but otherwise nothing has been done to it.
79_bronco is offline
post #2 of 16 Old 04-03-2013, 07:25 PM
dslbrnr's Avatar
Thats strange every time I open mine, I get a steady stream. 8,000 miles and haven't seen any water in the fuel yet. I check about once a month. Sounds like something may be clogged in the spout.
SOLD 2012 F350 CC, SB, Lariat 4X4, 3.31's, E-Locker, Line-X'd
dslbrnr is offline
post #3 of 16 Old 04-03-2013, 10:29 PM
I checked mine at 2K and not a drop of water; you should however get a steady stream of diesel flowing out. Did you loosen it all the way? If so have the dealer take a look at it.
Ford does not recommend additives (per the manual); just go with a top-tier fuel (IMO Chevron/Texaco for diesel).
2013 F-250 Lariat
JSolve is offline
post #4 of 16 Old 04-03-2013, 10:51 PM Thread Starter
79_bronco's Avatar
I did loosen it quite a bit (enough to make it come out around the knob). I will maybe try again tomorrow. As far as fuel, I have been using a local place. I see people stop there quite often for fuel but not alot of traffic. There are a few BP's around too, but I never see anyone buying diesel there.
post #5 of 16 Old 04-10-2013, 09:04 PM
desertnomad's Avatar
Agree, that is very strange. Regardless of water present or not you should get a steady stream of fuel. At this point I would be very curious and would pull out the housing and check the bowl for debris/blockage which you shouldn't have any and check the filter as well. Should be very clean and no metal filings. Since your vehicle is still brand spanking new I would make a stop at the dealer.
BTW, per the manual Ford states fuel additives should not be necessary which assumes where ever you get your fuel it meets diesel spec. Therefore Motorcraft fuel additive (cetane booster) or other similar additive which meets Ford specs is recommended.
2012 F350 6.7L 4x4 Lariat Ultimate FX4, Chrome package, Nav, SRW, CC, LB, 11.5K GVWR, 3.55 ELA, Toyo MT, Duraflaps
2009 Carriage Cameo 35SB3, 12.4K dry, 36' Fiver
desertnomad is offline
post #6 of 16 Old 04-14-2013, 12:07 PM Thread Starter
79_bronco's Avatar
Well I finally attempted again just due to the dealer not being able to get me for another few days and the fuel came out without issue and it seemed clean to me. Fuel Water Seperator Question-imageuploadedbyag-free1365966360.506873.jpgFuel Water Seperator Question-imageuploadedbyag-free1365966383.153316.jpg
2012 F-250 Lariat Crew Cab Short Bed 4x4 FX4
Ranch Hand Front and Rear
30in Rigid E Series Light
Bilstein 5100 Series Shocks
Truck Cover USA American Work Cover with Toolbox
Kenwood DNX570HD Head Unit
post #7 of 16 Old 04-14-2013, 12:12 PM Thread Starter
79_bronco's Avatar
Another picture from a power aid bottle.
post #8 of 16 Old 04-14-2013, 02:51 PM
dslbrnr's Avatar
Looks good.....
dslbrnr is offline
post #9 of 16 Old 04-18-2013, 01:42 PM
I assume the water in fuel warning light and message will come on when the DFCM seperator has a half a cup of water in it. Kinda like my dog scratching at the door to get out. I get the sign, and then I take action.
I don't think it is necessary to drain the DFCM every month. I will do it at oil changes or when the warning light comes on. Make sense?
2013 F350 CC 6.7 4x4 Lariat 3.31
Black, Leer Cap, 18" Wheels
Grandpa's Camper Puller
dbj216 is offline
post #10 of 16 Old 04-18-2013, 06:30 PM
Only takes a few minutes and I'm not taking chances. If the WIF comes on it's forever recorded.
