6.7 egr delete and cheaper tuning but keep urea - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-29-2013, 05:00 PM Thread Starter
darthman's Avatar
My father has a 2012 ford f350 6.7 all stock except for a levelling kit and since its a work truck up here in northern Alberta it idles a lot. He wants to delete the egr because his old truck a 07 6.0 saw nothing but egr problems. He wants me to research this for him, so I'm looking for a egr delete kit and and a cheap tuner to delete the egr code but keep the urea and dpf working. He's not after any added horsepower or anything like that. So where can I find parts like this can anyone post links. Low cost is pretty important here too. Thanks for your help
darthman is offline
post #2 of 10 Old 03-29-2013, 05:20 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
if i understand correctly, the 6.7 egr is good enough to keep. i could be wrong tho. i do know the egr on a 6.4 was better than the 6.0s were.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 10 Old 03-29-2013, 05:26 PM
HorseMover's Avatar
Quoted: 29 Post(s)
Much better than 6.0's but still an issue with excessive idling it appears.
http://www.powerstroke.org/forum/6-7...gr-cooler.html
2012 F-350 CC Lariat Dually
HorseMover is offline
post #4 of 10 Old 03-29-2013, 05:27 PM Thread Starter
darthman's Avatar
Friend of ours already had to put one in at 40000km clogged.
darthman is offline
post #5 of 10 Old 03-29-2013, 06:35 PM
BIG Laing's Avatar
If your going to spend $1000 on a tuner capable of removing the EGR, Why would you not straight pipe it for another $400? Or get a DPF delete pipe for $150?
BIG Laing is offline
post #6 of 10 Old 03-29-2013, 07:02 PM
I too work in the patch and haven't had an issue with idling my 2012 pretty frequently. If you're going to get a tuner to delete EGR you might as well get rid of the DPF and urea anyways because if push comes to shove and you want to make a warranty claim the dealer really isn't going to care that the DPF is still on there.
2012 F350 Lariat SRW CCSB 4x4 - Vermillion Red
Icon 7" Lift, BMF Novakane, 37x13.5x22 Toyo MT, MBRP Filter Back, 2WD Chin Spoiler, RDS 150 Gallon Tank
turboryan is offline
post #7 of 10 Old 03-29-2013, 07:10 PM
even if u did delete the egr and kept the dpf system in place the dpf will not be working to my knowledge you can not only turn one off . im deleted idle daily and love it,the 150 extra for a delete pipe well worth it .
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #8 of 10 Old 03-29-2013, 07:30 PM
BIG Laing's Avatar
If the DPF is present, and your not going into regen, you're going to have major problems.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
post #9 of 10 Old 03-29-2013, 07:42 PM
it just dosnt make any since to me to keep the dpf on and remove the egr and like said above gonna cause major issues i guess i could have worded my first response better .
lhood6.7 is offline
post #10 of 10 Old 03-29-2013, 07:54 PM
BIG Laing's Avatar
It doesn't make sence to only do 1/2 the deletes.
