Firestone or Airlift - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-14-2013, 11:30 AM Thread Starter
mach14604's Avatar
I am looking to get either one these airbags. I did a search but nothing really of a sure answer came of this. It seems like most have Firestone. My 4 wheel drives shop is pushing Airlift. But I kind of want Firestone. Is one better than the other? The Firestone kit I Am told by them is more expensive also. What does everyone run is one better than other.
Want to Buy Ford Racing M-55 Exhaust
mach14604 is offline
post #2 of 12 Old 03-14-2013, 01:32 PM
BadDogPSD's Avatar
Quoted: 3 Post(s)
I've used Firestone in the past and they have worked well. I've heard good things about Airlift too. If I were buying a set now, I'd probably go with Airlift as they do the same thing for less $$.
2013 F350 CC LB 4x4 Lariat
BadDogPSD is offline
post #3 of 12 Old 03-14-2013, 01:33 PM
fordpwrstroke7's Avatar
I'd go Firestone. Had them on my last truck and now on my 08.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #4 of 12 Old 03-14-2013, 02:02 PM
I think that they are about even. On my old truck the Firestone bags worked great but I hear the Airlifts ride a little nicer. I would look at the instructions for both and see if either require drilling in to the frame. Airlift also has a model with an internal jounce protector that looks like it might be a good thing to have. That model is more $$ though. With either system I would get a compressor system to inflate/deflate the bags. Didn't have one on my last set up and wished I did.
John
Action H53 is offline
post #5 of 12 Old 03-14-2013, 05:12 PM
ucpa111's Avatar
Quoted: 3 Post(s)
I thought I read one of them had interference if you had the 5th wheel prep package. It sounded like you could still install...just required some grinding. I think it was the Airlift, but cannot remember.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #6 of 12 Old 03-14-2013, 05:37 PM Thread Starter
mach14604's Avatar
The one thing i could find is the fact that the Firestones can hold more air compared to Airlift. Don't know if that is enough to buy though.
post #7 of 12 Old 03-14-2013, 05:53 PM
van-boy's Avatar
i went with firestones. not that they were any better, just what the local shop was pushing.
bailey
cut me some slack, its a work truck.
van-boy is offline
post #8 of 12 Old 03-14-2013, 07:25 PM
Quoted: 2 Post(s)
Re: Firestone or Airlift
The hell with airlift bags. A nightmare to assemble
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #9 of 12 Old 03-14-2013, 07:28 PM
I just installed the Firestone on my 2012 F350, I have the fifth wheel prep and the Firestone bags fit perfectly without having to drill or relocate anything. I was going to do the Airlift but, I read where alot of people that installed them with the fifth wheel prep package had to do some pretty extensive drilling to get them installed.
Boss 302 is offline
post #10 of 12 Old 03-14-2013, 07:40 PM
350ninty7's Avatar
Also the maintenance factor, that's why I installed Timbren SES on my 2012 F350. No contact when running empty and plenty of support to reduce the squat factor with 2,220 lbs of 5th Wheel Pin weight. I have the Reese 5 th Wheel Frame Brackets and could not add the Firestone Air Bags due to the location of where the brackets mount on the side of the frame.
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
