First Oil Change - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-09-2013, 06:59 PM Thread Starter
Traveling Man's Avatar
First Oil Change
Self performed the first oil change today at 7,300 miles. The computer did not say "oil change required" but had been saying "oil change soon" for a couple of weeks. Pretty much straight foreword other than the dipstick is extremely difficult to read. I had to reinsert the dipstick several times to get the correct oil level. IMO the dipstick on this motor leaves much to be desired. How many quarts does this motor take anyway?
Traveling Man is offline
post #2 of 13 Old 03-09-2013, 07:01 PM
I will be doing my first change this week also. As the required amount in the manual says 13 I believe but seems like I remember people saying it takes more. How much did you add in?
Pjosh6 is offline
post #3 of 13 Old 03-09-2013, 07:39 PM
350ninty7's Avatar
Completed my first change today at 4,000 miles, changed early because IM at 6 months plus IM towing a 5th Wheel. I poured in 13 quarts as per the Ford manual. Probably as much debate with oil amounts on the 6.7 as there was with the ol' reliable 7.3 Turbo PSD at 14 quarts. The dip stick on the 6.7 has to be the worse design for location and reading oil level ever for a Ford F Series pick up.
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
post #4 of 13 Old 03-09-2013, 07:40 PM Thread Starter
Right at 14 quarts. The dipstick is very hard to read the level.
post #5 of 13 Old 03-09-2013, 07:46 PM Thread Starter
I towed my camper twice, a total of about 200 miles. 13,000 lb 5th wheel and it towed it wonderfully. I wanted to change the oil sooner but FoMoCo clearly says to trust the computer.
post #6 of 13 Old 03-09-2013, 08:47 PM
HarvestingInternationally's Avatar
^ that's hard to do...I don't think I could trust the computer
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #7 of 13 Old 03-09-2013, 09:29 PM
palmettopowerstroke's Avatar
First Oil Change
I kept waiting and waiting for the computer and finally decided to go ahead and change the oil around 7k. I couldn't wait any longer especially for the 1st change. You're right about the dipstick. It's definitely not the easiest to read. I used 13 qts of Rotella 5W40 and from what I can tell its just right.
Sent from AutoGuide.com App
palmettopowerstroke is offline
post #8 of 13 Old 03-10-2013, 06:32 PM
350ninty7's Avatar
Personally, I don't care what that oil life computer says that's why they have a reset button. IM staying with 5,000 mile interval especially when towing a 36 Ft 12,000# 5th Wheel.
I reset the "A" gauge monitor every fill up and the "B" gauge will be reset at oil changes and this will be my visual oil change mileage monitor, plus record the gals of fuel used, hours, and fuel mileage over the course of my last oil change.
IM taking my first 300 mile trip pulling my 5ver next week and aside from a test tow the 6.7 is awesome. My test tow of 20 miles with starts, stops, hills up and down met my expectations. There was zero drive line shutter on starts and the tow haul feature is very nice.
SOLD and Missed
AFE Stage 2
TW Tunes
WARN Winch
post #9 of 13 Old 03-11-2013, 03:58 AM Thread Starter
Had to drain about one quart the next day. Oil level was easier to read the next morning.
post #10 of 13 Old 03-11-2013, 09:34 AM
6.7strokin's Avatar
Put 13 quarts in it. Crank it up and let it run for a few minutes to heat up the oil. Let it sit for a minute or two then read the stick. Pouring in cold oil and not cranking the motor will not give you an accurate reading on the dip stick.
6.7strokin is offline
