2 small issues with my 250 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-27-2013, 07:01 AM Thread Starter
All,
I purchased a used 2012 F250 several months ago, virtually no miles, I love the truck. there are two small things bugging me.
The card that is supposed to have the door lock code on it was not with the vehicle. I called the dealer and they said they would have to hook it up to the computer to get the master code so that I could put in my own code. of course they would charge me for that. Does anyone know if that is really true, or is there some other way to get the master code for the door locks?
the other problem is this truck has the back up sensors that beep when you are getting close to something. It works fine on flat concrete or pavement, but when you get on to a stone driveway or anything that is not perfectly flat, it beeps all the time. My 08' had them and did not do this. Dealer is not aware of any adjustments that can be made to this. It is unfortunate, but it makes that system pretty much useless.
Any ideas on the above issues would be greatly appreciated.
Thanks in advance for your help
rinker312 is offline
post #2 of 10 Old 02-27-2013, 08:26 AM
factoryflood's Avatar
My back up sensors do the same thing. Pulling out of my driveway is a very slight downhill and as soon as the rear drops even the tiniest bit the thing starts blaring.
2012 F350SRW CCSB
H&S Mini Maxx with MCC, Spartan with war hammer(FOR SALE), 5" down pipe back exhaust, AFE Stg 2 Cold Air Intake, 6k 55w HIDS, Eagle Alloys 014 20x9 0 offset wheels, 35x12.50R20 Toyo Open Country AT2 Xtreme, UWS toolbox
Inside- Pioneer AVH3200BT, 2 Kicker CVT 12's, Kicker ZX1000, 4 gague wiring, Custom sub box, 20% tint all the way around
factoryflood is offline
post #3 of 10 Old 02-27-2013, 09:14 AM
vlxjim's Avatar
The code is listed on the door or alarm module it's under the dash. I'm not sure on its location.
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #4 of 10 Old 02-27-2013, 10:07 AM
HorseMover's Avatar
Quoted: 29 Post(s)
I though I remember seeing an adjustment for the back up sensors somewhere...let me see if I can find it.
2012 F-350 CC Lariat Dually
HorseMover is offline
post #5 of 10 Old 02-27-2013, 10:16 AM Thread Starter
Horsemover - that would be awesome if there was an adjustment. even on level terrain, it goes off if the surface that I am on is not smooth. Let me know.
VLXJIM - I read that somewhere also but I have looked under the dash and If I recall correctly I saw multiple modules and many numbers. Does anyone have any more specifics on where the module is and what numbers?
Appreciate all the help.
post #6 of 10 Old 02-27-2013, 05:46 PM
JRW6.7's Avatar
Re: 2 small issues with my 250
Bought mine used and the master code was missing too. Found it behind the passenger side kick panel. I want to say it's a 5-6 digit code.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
JRW6.7 is offline
post #7 of 10 Old 02-27-2013, 05:57 PM
Lf83's Avatar
Quoted: 14 Post(s)
5 digits. Dealer did my buddies for free when he had $$$$ service done
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #8 of 10 Old 02-28-2013, 02:13 PM
psi_2_high's Avatar
mine was free at ford it took 30 seconds
2011 F350 FX4, Lariat, Recon Lights, more to come!!
2005 F250 ,Garret PowerMaxx, Studded, Bulletproof EGR Delete, 12" Rize quad link / King Coils / King Ress shocks, 4.56 Gears, Full HD interior, Straight Piped, Toyo 40/15.50/22 Fuel Hostage Deep Rim. And a ton more stuff i forgot!!
psi_2_high is offline
post #9 of 10 Old 02-28-2013, 04:12 PM
mach14604's Avatar
I really don't think you should be charged to get the code for the door. It does not seem right.
Want to Buy Ford Racing M-55 Exhaust
mach14604 is offline
post #10 of 10 Old 03-03-2013, 03:07 AM
Keyless Entry Factory Code Displays!
I believe you can get read the factory set keyless entry code right in your driveway, for FREE! The procedure is on page 74 of the Owners Manual.
Take both of your keys to the truck. Place a key in the "ignition" and turn it to on, no need to start the truck. Then back to off. Now place the second key in the ignition and turn it to on, and back off.
Watch your information display between the gauges. The code will display for a few seconds after any other warnings are displayed.
Neat!
dbj216 is offline
