2013 F250 Fox Shocks to Replace Ranchos - Ford Powerstroke Diesel Forum
post #1 of 17 Old 02-17-2013, 06:59 PM Thread Starter
I tried contacting Fox, but I haven't had any luck hearing back from them. My truck is stock and I am not interested in lifting it. I want the Fox Shocks because I like the quality and performance. I am needing to confirm what model numbers I would need for my truck in stock form.
From what I have read the fronts are 980-24-676 and the rears are 980-24-647, are these numbers correct?
Thanks in advance
2013 F250 FX4 King Ranch 6.7 Powerstroke
-built Dec 2012 purchased Jan 2013
-HID Heads and Fogs (Retro Solutions)
-all LED interior lighting
-Nitto Terra Grapplers 295/60/20 on stock wheels
-Readylift Stage 1 1-1/2" leveling kit
-Fox Shocks all around
Lgowens2 is offline
post #2 of 17 Old 02-16-2014, 03:44 PM
hopperwagonbob's Avatar
Wow a whole year and no replies? I'm interested also. Anybody?
hopperwagonbob is offline
post #3 of 17 Old 02-16-2014, 03:57 PM
I sure like that regular cab Hopperwagon.
claws314 is offline
post #4 of 17 Old 02-16-2014, 04:49 PM
Thanks, in the process of ordering a 2015. Can't decide on color
post #5 of 17 Old 02-16-2014, 05:06 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
I have run the 2.0 IFPs i like em alot they are valved soft i recommend them to anyone with just a leveling kit or small lift WITH STOCK LEAFS if you have progressive rate springs you will want something more firm
the correct numbers for your application is 980-24-646 for the front and 980-24-653 for the rear
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
The Following User Says Thank You to Carli'd6.7 For This Useful Post:
hopperwagonbob (02-16-2014)
post #6 of 17 Old 02-16-2014, 05:22 PM
Hoverp's Avatar
What fox shock would give me the most comfortable ride on my stock truck ? 20s . I have a 2014 platinum f350 fx package . The ranchos are valved a bit stiff.
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #7 of 17 Old 02-16-2014, 06:40 PM
Carli'd6.7's Avatar
If you want the without a doubt softest shocks get Icon VS 2.0 Non Resi and Fox IFP 2.0's in a close second if you want to go even softer get Icon VS 2.5 but order them with compression adjustment knobs and you can literally just turn a knob on the top of the shock to dial in your ride ANY WAY YOU WANT it it sort of like the technology on the Rancho 9000s but they don't suck
If your truck is stock the Fox part #s are 980-24-677 for the front and 980-24-653 for the rear if you are leveled the part numbers are the ones I posted in the previous post
post #8 of 17 Old 02-16-2014, 06:42 PM
Carli'd6.7's Avatar
Oh yea and let some air out of your tires , its free and gives you the biggest ride improvement look at the inside your door an see what the minimum spec is and put 5 lbs less than that and that should keep your TPMS light off and improve your ride big time
post #9 of 17 Old 02-16-2014, 06:47 PM
Hoverp's Avatar
Thanks, I appreciate it! What dealer do you know of that has good prices on those shocks you mentioned?
Hoverp is offline
post #10 of 17 Old 02-16-2014, 06:49 PM
Carli'd6.7's Avatar
I usually go through SDHQ for Icon and Auto anything for Fox
Goatro (04-06-2015)
