Icon Leveling Kit Alignment Question? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-12-2013, 04:41 AM Thread Starter
Hi guys,
I am having an icon stage 1 leveling kit installed as we speak. I did purchase the icon track bar with rod end upgrade and 4 inch rear blocks (my truck is a 250) which will both be installed as well. I have searched a lot and it seems that when you align these trucks after the leveling kit you have to be pretty careful about caster to keep from wearing out front end parts.
So my questions are:
1. You HAVE to use the icon supplied caster shims to get the alignment right correct?
2. Do the trucks need to be aligned to factory specs or to another set of specs?
3. If the specs are different then factory specs are there some already out there that someone can share or anyone that I can speak with to make sure that the truck has been aligned correctly to make sure I don't start wearing out front end parts as well as a brand new set if 35x12.50s?
Sorry guys I'm new to leveling kits, lifts, etc so pardon me if any of my questions are ignorant. I just want to make sure I do it right the first time.
Thank you in advance for your help!
RIDE3311 is offline
post #2 of 6 Old 02-12-2013, 08:39 PM
I have the ICON leveling kit on my truck and I took it to Desert Rat and they did the install/alignment and the guy said that it was the easiest truck to align and was almost aligned perfectly due to the supplied cam kit.
I have had the leveling kit installed for about 18 months now and I have had no tire wear issues due to alignment. I have taken the truck in for alignment and was told that I did not need it and I take the truck off road quite often.
I have the General Grabbers and I have a few chunks missing off the tread, the power on these trucks are unbelievable and the tires are very beefy!
offroadsd is offline
post #3 of 6 Old 02-13-2013, 02:39 AM
vlxjim's Avatar
It runs just find the way Icons sets it up. It could use a little more caster but you would need a 4 link to get that. After you get it installed it will steer real easy do to a little less caster.
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #4 of 6 Old 02-14-2013, 04:19 AM Thread Starter
That's great to hear! I appreciate your feedback. You are right about the power these trucks have even bone stock.
Awesome! Thanks for the feedback. Love your truck by the way. Looks real tough!
RIDE3311 is offline
post #5 of 6 Old 02-14-2013, 07:30 AM
1. Yes
2. Factory spec, but push a little more toe than centered.
3. I put similar tires on mine, no probs
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #6 of 6 Old 02-18-2013, 05:02 AM Thread Starter
Originally Posted by TrickTruck View Post
1. Yes
Thanks for the info TrickTruck!
RIDE3311 is offline
