Drw or srw - Ford Powerstroke Diesel Forum
post #1 of 22 Old 02-09-2013, 07:15 AM Thread Starter
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
Drw or srw
I just want to know if a dually is worth owning nowadays since the srw tucks have a decent payload. The heaviest I'll be pulling is a fifthwheel camper trailer. How long idk since it will be awhile before I purchase that.
I just need to know if I need a drw for that or I can get away with a one ton srw.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #2 of 22 Old 02-09-2013, 07:18 AM
fordpwrstroke7's Avatar
How heavy is the 5th wheel? How often do you tow? How far do you tow? Where do you tow? Those are all questions you'll have to answer.
Your average weekend warrior has no need for a dually. Duallies are nice from a stability standpoint, especially when you pass or are passed by a semi.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #3 of 22 Old 02-09-2013, 07:41 AM Thread Starter
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
Dunno weight. Deal is get a truck that mostly will be driven unloaded. With the occasional trailer. Not often and it will prolly sit most of the time since I would be living in it when I'm down south on work. The drive is about 3 ish hrs.
That's what I thought since I wouldn't be towing as much. It would be more like moving it around or drive it back.
Also with the mindset of using it for vacation once in a while.
I was thinking a 2 axle max trailer that's under 30'
Sold
LSP Group Threads
Jarrod B is offline
post #4 of 22 Old 02-09-2013, 07:49 AM Thread Starter
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
Guess for what I will do with the trailer, a dually would be overkill lol.
Sold
LSP Group Threads
Jarrod B is offline
post #5 of 22 Old 02-09-2013, 07:52 AM
Koda22's Avatar
Quoted: 5 Post(s)
Yea unless ur gonna be towing for a living, or a lot a dually is gonna be more then ya need....it's nice to have if u tow a lot, but just more of a pain if ur only using it once in a while...just sick with a single wheel if u will do everything ya need
Koda22 is offline
post #6 of 22 Old 02-09-2013, 10:42 AM
Agreed, stick with the srw for your usage.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #7 of 22 Old 02-09-2013, 11:08 AM
ucpa111's Avatar
Quoted: 3 Post(s)
If pulling a large 5th wheel...I'd opt dually. Why? Imagine a blowout on a SRW vs dually. Catastrophe vs big inconvenience.
That being said, many people pull 5th wheels with SRWs...just make sure you keep the rubber in good shape and replace as necessary. And, a set of air bags may help you as well.
Good luck. I'm sure you'll love whatever you get (except trying a drive thru with dually LOL).
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #8 of 22 Old 02-10-2013, 05:52 AM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
After pulling the loads I have in my DRW, I don't feel as comfortable pulling over 10K on a SRW truck. The stability and redundancy in the event of a blow out, far make up for the additional parking space in my eyes.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #9 of 22 Old 02-10-2013, 07:15 AM Thread Starter
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
Basically the only difference between the two trucks is the 2 extra tires correct?
Sold
LSP Group Threads
Jarrod B is offline
post #10 of 22 Old 02-10-2013, 07:30 AM
Kind of. The gear ratios are more limited, I believe, on the DRW. Also, a DRW sits lower than an SRW 350 in the rear.
From the sounds of it, a DRW is not necessary at all for you. I tow tandem duals all week and I've never had a problem with my SRWs. If you get an SRW, just keep your speeds a little lower and always check your tires for signs of wear.
Go SRW and never look back. If you start hauling more frequently or heavier, maybe consider a dually. In the mean time, have fun only having to pay for 4 tires instead of 6!
2008 F-350 CCLB
