6.7 idling? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-07-2013, 09:41 AM Thread Starter
brendan.9's Avatar
6.7 idling?
Hey guys still haven't bought a truck between the two 6.7 we are farmers and live one mile from the farm the truck will be used alot of short runs to the barn and back and lots of idling as it is very cold here in the winter. as the 13 ford you won't be able to delete and the dodge i will probably delete is the ford still going to be reliable with more idling.
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #2 of 8 Old 02-07-2013, 04:08 PM
Quoted: 4 Post(s)
I think you are ok with the exception of watching the antifreeze. Apparently more idling can degrade the antifreeze.
FastCarsSpeed is offline
post #3 of 8 Old 02-07-2013, 04:20 PM
6.0f250firstcar's Avatar
If you're going to be idling a lot, install a high idle switch. If you're going to buy it, buy it now before all the deletes are gone
Ryan
6.0f250firstcar is offline
post #4 of 8 Old 02-10-2013, 04:22 PM
mor4wd's Avatar
I'm in Central Michigan for work and we're having temps of about -10F every now and then and I idle my truck for 6-8 hours a day. The coolant temps quickly drop off to about 140 and stay there if it's below about 20F. I don't have a high idle switch but recently read an article stating that high idle has minimal effect on keeping an engine warm (it does aid initial warm up). My truck has 80k miles on it and about 700 idle hours. No problems, no "making oil" or anything else. Mine is deleted however.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #5 of 8 Old 02-10-2013, 11:11 PM
6.7 idling?
The ECM in the 2013 ram is all new and you likely would not have a delete solution available for them either.
Sent from AutoGuide.com App
2012 F350 Lariat SRW CCSB 4x4 - Vermillion Red
Icon 7" Lift, BMF Novakane, 37x13.5x22 Toyo MT, MBRP Filter Back, 2WD Chin Spoiler, RDS 150 Gallon Tank
turboryan is offline
post #6 of 8 Old 02-11-2013, 09:44 AM
psi_2_high's Avatar
so will you always be able to do the deletes on the 2011 ??
2011 F350 FX4, Lariat, Recon Lights, more to come!!
2005 F250 ,Garret PowerMaxx, Studded, Bulletproof EGR Delete, 12" Rize quad link / King Coils / King Ress shocks, 4.56 Gears, Full HD interior, Straight Piped, Toyo 40/15.50/22 Fuel Hostage Deep Rim. And a ton more stuff i forgot!!
psi_2_high is offline
post #7 of 8 Old 02-11-2013, 05:40 PM
I think if you look hard enough, yes. The EPA is cracking down on tuners but there'll always be some kicking around. And the guy that runs DuramaxTuner.com has come out with a new ECM flash that's apparently kind of similar to EFIlive, so maybe there's still hope.
I loved having a big horsepower cummins but now I'm okay with having a good warranty and a truck that has been nice and reliable. My 6.4 buddies are always complaining about their trans is starting to go or they think they're starting to push coolant. That gets real old when you're a thousand KM's from home.
post #8 of 8 Old 02-12-2013, 04:04 PM
Paul "MadMax"'s Avatar
I have been speaking with a rep from Spartan and they are currently in R&D on the 2013 and they have heard about all the fines and restrictions put on a few companies by the EPA but they have no such warning on stopping sale and distribution of their tuners. I am going to get one for mine as soon as it is available just to have it in case the EPA shuts all the companies down. Also along with all the other required items... dpf delete, air box etc etc.
2013 F450 King Ranch
Paul "MadMax" is offline
