Wheel bearing? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 02-04-2013, 02:54 PM Thread Starter
Question Wheel bearing?
I was hearing a grinding noise. Which was definitely a rotational issue. Brought the truck to the dealership and they say its the front wheel bearings. My question is the truck has 34000 miles on it, is it normal for the bearings to go out this soon?
strokedagain11 is offline
post #2 of 17 Old 02-04-2013, 03:23 PM
bronze 6.7's Avatar
My left front went out and it had 59,000 on it. I live in southeast Missouri and had to get one from a ford dealer in Indiana because my local dealers were saying they were on backorder from ford. They don't make things like they use to and there is no reason wheel bearings should be going out this early on a 60k dollar pickup. I have a 2002 f250 with 167,000 on it and it's never had one put in it
2011 CC/SB
mini maxx
mbrp duals
torq 2.1
afe intake
20x9 RBP 94R
35x12.50 nitto trails
bronze 6.7 is offline
post #3 of 17 Old 02-04-2013, 07:40 PM Thread Starter
Apparently the wheel bearings aren't built Ford tough. Well the part is on back order. They are not sure how long it will take to get in. I was told its completely ok to drive the truck. I had them put a note on the paperwork that "owner was advised by dealership ok to drive vehicle until part arrives". I also snowplow with the truck and they said no worries. Hopefully part arrives soon.
post #4 of 17 Old 02-11-2013, 06:39 PM Thread Starter
Update: the part came in on Friday. Brought truck in today they said your truck is done. Picked it up and clear as day the noise is still there. Have an appointment tomorrow to see what's going on. Will update again when I get some answers.
post #5 of 17 Old 02-25-2013, 07:43 AM Thread Starter
Update. Now the dealership is telling me its just my tires that are making the noise. I have duratrac studded tires I use for the winter. I told them it was making the same noise before I switched to my winter tires. The ones that came with the truck ( rugged trail ). I really don't think it's the tires I said. His response was well at least you have a 60,000 power train warranty. Can anyone recommend a dealership with perhaps more knowledgeable techs in Utah. I'm from Park City. I'm just confused how they can first say its the wheel bearings, replace them and they say its your tires. I have two more months before I switch my tires back and really want to remedy this before then.
Thanks in advance,
Brian
post #6 of 17 Old 02-25-2013, 11:11 AM
i had the exact same problem except my truck had 25,000 miles on it. the noise only comes out when the truck is in 4x4. its like a loud ticking or clicking noise. brought the truck to the dealer and it sat their for over a week waiting for the same back ordered wheel bearings put the truck in 4x4 the following weekend and the noise was still there. i am running nitto trail grapplers so that is not the problem. they were also supposed to recalibrate my tire size for 35'' and now my speedo is off by 6mph
cmart264 is offline
post #7 of 17 Old 02-25-2013, 12:00 PM
Lf83's Avatar
Quoted: 14 Post(s)
Wheel bearing?
I had same problem ... dealer told me almost same things as you guys. I pulled lug cover off and found one side was locked and other was in free. I turned the hub to free and that fixed mine. I had 15k when I noticed the sound.
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #8 of 17 Old 02-25-2013, 01:54 PM Thread Starter
I'll check that out lf83. I do notice now whenever I switch to 4x4 it makes a loud click. That's something that started after they replaced the bearings. It's frustrating when your told its one thing and its not.
post #9 of 17 Old 02-25-2013, 02:01 PM
Lf83's Avatar
Quoted: 14 Post(s)
Wheel bearing?
Yep. Loud pop about 3-5 feet after I would take off from stop. I have 35" mtz's so couldn't here sound that well either.
leveled 2011 F250
Fox 2.0 Shox
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #10 of 17 Old 02-25-2013, 02:05 PM Thread Starter
Just checked both lockers are set to auto. Is there another way to check them other than the locker itself?
