6.7 Rod Bearing at 37K - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-02-2013, 12:51 PM Thread Starter
Truck has been at the dealer 4 weeks. Ford is trying to decide if they will replace with a short block or long block. F-350 4WD has been relatively trouble free. Gets 12 MPG pulling 40Ft 15K 5th wheel. Oil was changed every 5K until I switched to synthetic and then went to 10K.
jgrade is offline
post #2 of 7 Old 02-02-2013, 03:30 PM
George C's Avatar
I didn't have anything to do with switching to a better oil.
Good luck, let's hope you get it back soon.
2008 F-350
KEM 345 tuned.
George C is offline
post #3 of 7 Old 02-15-2013, 10:54 AM Thread Starter
Not a rod bearing
After tear down broken lifter discovered. Lifter broke lifter bore, flattened cam lobe, damaged piston and scored cylinder wall. Ford dealer ordered long block. 6 weeks into it long block received. New long block now has cast aluminum oil pan. I have not been able to find out if there are any other improvements.
jgrade is offline
post #4 of 7 Old 02-15-2013, 01:46 PM
Tuxedoblack's Avatar
6 weeks wow You got it back yet?
Tuxedoblack is offline
post #5 of 7 Old 02-15-2013, 11:48 PM
dieseldesi's Avatar
Quoted: 4 Post(s)
Do they provide a loaner vehicle during this time?
dieseldesi is offline
post #6 of 7 Old 02-16-2013, 03:56 PM
Glad to hear you are getting a new bullet..
poormanscat is offline
post #7 of 7 Old 02-26-2013, 05:38 AM Thread Starter
Truck is still at the dealer. New motor is finally in the frame. Quite few upgrades with the new motor. Caruso (Long Beach Ford) provided me with a new Lincoln MKS loaner the whole time. Having problems towing the 5th wheel with the Lincoln though. I visit the truck and talk to the mechanic weekly.
jgrade is offline
